Question about Texas Instruments TI-84 Plus Calculator
LCD screen will not change contrast
All of a sudden, the numbers on the LCD screen are very, very pale. I have tried looking in the manual and online both, and I've read that you need to press the 2nd key and the up botton in order to make it darker, and I have tried this and there is no change. I have also changed the batteries, and there was no change again. What could this be? Thank you!
  • 35 Answers
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem.
Posted on Aug 27, 2007
SOURCE:
How do I adjust contrast
Check all pix sources first, Use Menu to put brightness to mid range, then contrast to 80-100%, if pix is still bad the problem is either main board or LCD panel
Oct 19, 2014 | LG Televison & Video
My Envision LCD Monitor screens turns gray once its power on. I have tried changing contrast will not work.
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Mar 27, 2014 | Envision G22LWK 22" LCD Monitor
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
My lcd backlight is very pale, how can I encence the brightness??
Reading your user manual on page 12, bullet 9 you will find the method of changing the contrast of the display. There is no brightness adjustment possible, however the contrast DRASTICALLY affects the readability of the display.
Jul 23, 2011 | Korg PA500 61KEy PROFESSIONAL ARRANGER...
How do i adjust display screen on nec aspire phone? Is too dim all of the sudden.
The keyset’s display provides a 3-line, 24 character per line alphanumeric
display that displays various information for the telephone
either while on a call or while idle. You can change the contrast of the
display as well as the language used when displaying the prompts.
1.On an idle telephone with no BGM,
or .
Pressing either volume key adjusts
the LCD display.
If BGM is enabled for the phone, in
order to change the contrast, it must
first be disabled (CALL + 825) or it will
adjust the speaker volume.
1. Press + + the language
number to be displayed (00-12).
0 = Japanese 1 = English
2 = German 3 = French
4 = Italian 5 = Spanish
6 = Dutch 7 = Portuguese
8 = Norwegian 9 = Danish
10 = Swedish 11 = Turkish
12 = Latin American Spanish
To change the
displayed language:
To adjust contrast:
58
Feb 24, 2010 | Lands Phones
The picture on my Vizio 42" flat screen suddenly shifted to a whitish pale color with ghostly looking images that look like negative film.
This is the fix for the Main board repair :
Locate IC 32 small 8 pin surface mount near top of Main Board and remove. Short pin 2 to pin 5. (pin 5 through 8 are together and pin 2 and 4 are together)
You will need a good TV Tech to do this for you.
Aug 04, 2009 | Vizio VO42L 42 in. LCD TV
GE Profile dryer-LCD panel flickers!
Look in your Use and Care book on how to change the screen contrast. It has two settings. If changing the contrast setting doesn't do it, you need a new display board. GE Parts 1-800-626-2002
Dec 16, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Re-Sized Photos are Grainy
This camera takes pictures with a Ppi of 72. That is why the pictures look huge on the screen. To get good quality prints you need to have at least 200 ppi, or even better, 300 ppi.
Or, the contrast of the pictures may be to low. I have an FZ7 too, and I always tweak the contrast and color saturation before outputting.
1. images straight from the FZ7 are generally low in contrast.
2. Pictures that are low in contrast might not look too bad on screen, but when they are printed they will look slightly greyish.
3. Low ppi pictures look fuzzy in print.
Maybe you can post a sample original picture??
Jul 06, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Texas Instruments TI-84 Plus Calculator Logo
191 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
