Question about Dryers
Dryer want start
Kenmore dryer want start,fuses good.having problem geting back cover off
  • 1 more comment
  • dbowman0123 Jan 08, 2009
    I have kenmore 90`s series dryer.It will not start.The fuses are good,connection is good.I`m having trouble removing back pannel to check internal fuse.How do i get the back panel off
    model no. 110 60907990
  • rojoma Mar 05, 2009
    I have a Kenmore 90 gas dryer that won't start. When I push the start button it make a noise like it want to start but won't. I am also having a hard time figuring out how to get in from the back.
    rojoma
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
does anything with the dryer work at all? if nothing works then from reading around it sounds like the motor went bad on you and they can be very spendy. but to make sure i need the model number and the exact brand.
thanks
tom
Posted on Jan 08, 2009
  • Thomas Jan 08, 2009
    a motor assembly from sears will cost $126.99 + tax
    you can go to this website and seee for yourself that the back whole cover can not be removed.
    http://www.searspartsdirect.com/partsdir...**.shcapp3206?modelNumber=110+60907990&pop=flush
    click on cabinet and you can see for yourself. now there should be smaller cover doors on the back that can be removed. the only fuse that is in this dryer is thr thermal fuse located on the bulkhead diagram number 59 on the diagram.
    let me know what else i can help you with cause it aint fixed tell you say so.
    thanks
    tom
  • 59 Answers
Mine was the switch for the door. I just eliminated the switch. The only problem was it wouldnt shut of when you open the door. Just turn the knob to off then open.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
With some dryers, failure of the door closed/lock switch/sensor would cause no power to the electronics inside. Try opening/closing and/or checking the locking tab of the door itself.
Good luck and Thank you for using FixYa.
  • 750 Answers
Hello dbowman0123You said, your Kenmore dryer want start,fuses good.having problem getting back cover off
Please send me the complete Kenmore model number as shown on the sticker inside the dryer door jam, so I may assist you!
waiting your response
    Scholar:
  • 86 Answers
If you give me the exact model number then we can fix it together!
  • Dryers Master
  • 19,396 Answers
If you give me the exact model number I can find the schematics.
    Genius:
  • 1,550 Answers
You need to provide model details to get step by step instruction to remove the back cover off.
  • SAM ANDERSON Jan 08, 2009
    Hope this picture will give you any idea to remove the dryer .
    Sergeant:
    Champion:
  • 338 Answers
Does the motor run when you hit the start button?
if no when you open the door can you spin the drum by hand without using a tremendous amout of force?
Kenmore Dryer-90 Series- Pushed Start button nothing happened
get a meter,unplug the dryer and read out the fuse,pull one of the wires off when you read it out,also when was the last time you cleaned out the dryer?if it's the fuse usually the air isn't moving very well,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line and make sure the outside vent is clear,if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the vent line,make sure you have 240 coming in at the back of dryer,you could have a blown fuse,if the thermal fuse is good,check the thermostats on the heater box and read out the heater,good luck,if i can help with anything else let me know
Mar 26, 2010 | Kenmore 62802 Electric Dryer
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
How do I find the fuses on an old (circa 1983) Lady Kenmore Sears Best dryer, that suddenly stopped working, to check if they are burnt out?
The fuses should be close to where the cord comes into the back of the dryer. You may need to turn the dryer on its side or remove the back cover to gain access. Unplug the dryer before starting your search.
Jan 29, 2010 | Kenmore Dryers
Push button and it doesnot start cheaked switch and it is good what could be wrong
on the kenmore dryers you have to take the back cover off, should be 9 quarter inch screws and when looking at the back of the unit on the lint trap cover on the left there will be a small white fuse with 2 prongs this is called the thermal fuse. There is one quarter inch screw holding it on just remove the screw and replace the fuse and that will fix ya all up. You can call sears with your model number to get the part number and price, they usually don't go for more than $10. Number is 1-800-4my-home.
Oct 04, 2009 | Kenmore 63942 Dryer
Dryer will not turn on although the timer is working
IF your hearig a click when you push the start button then the button and relay are good check the saftey switch on the door to see if it has come loose and follen down or moved back if the switch is not pressed the motor will not work also I have seen the switches go bad you need to unplug the dryer and cross the too wires togeather plug the dryer back in and press the start button if she starts order a new swith. The motor could also be bad you nees to remove the back cover and check to see when the button is pressed if you are getting the correct voltage you will need a volt meter to check this they cost around 10- 20 bucks if you have correct voltage from the wires and the conections to the motor are ok the motor is no good and needs to be replaced hope this helps...
Jul 07, 2009 | Kenmore Dryers
Kenmore 80 series elec.dryer will not start.have power to outlet.is there a fuse ??
There is a fuse :) If you pull out the dryer from the wall and unplug it Then yopu remove back panel.Once you have panel off at the bottom left corner there is a small white fuse with 2 small blue wires going to it.Good luck
May 06, 2009 | Kenmore 73952 Gas Dryer
Kenmore Gas Dryer will not start
i would check the thermal fuse on the back of the dryer where the vent come out remove the back panell it is a small white with2 blue wirs most of the time and one screw holding it in un less you dryer does not have a removeable back then there is a removable front cover acrose the bottom remove it and the fuse is on the blwer housing the in the front should look the same and described above.
Jan 19, 2009 | Kenmore Dryers
I have a kenmore 80's series electric dryer. It was working very well, then just stopped during a drying ( a light load) and has not turned back on since. Help, I need my dryer!
if filter is on top remove back cover just to left and above vent outlet will a small white object this a thermal fuse if for some reason vent becomes plugged or element should overheat it will blow ..if replacing fixes problem be sure vent hose is not flattened behind dryer and there is good air flow to outside
Aug 20, 2008 | Dryers
Kenmore Dryer electric 70 series will not start
The thermal fuse may be blown. The fuse is a white plastic item located behind the back cover on the blower box housing. It has two blue leads attached to it.
  1. Unplug the dryer.
  2. Remove the back cover.
  3. Identify the thermal fuse (white, two blue leads, one screw)
  4. Remove the two blue leads.
  5. Using a multimeter set to ohms, check the continuity of the fuse, it should "peg" the meter if the fuse is good, if the meter does not react, the fuse is blown.
  6. Remove and replace the fuse. Replacements can be found either online or at your nearest Sears.
Dec 31, 2007 | Kenmore 64952 Electric Dryer
No power!
Nov 01, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
259 people viewed this question
Top Dryers Experts
