Question about GE GSS25VGMWW / GSS25VGMCC Side by Side Refrigerator
GE GSS25VGMWW side by side refrigerator
Guru,
Water line does not dispense anymore. It's not locked and the filter is clean. If the resevoir is frozen, can I get to it myself or call service?
Thanks.
    Problem Solver:
  • 5 Answers
1st remove the line to the despenser at the valve and hold a cup under the valve and have someone try to dispense water, if water comes through the valve then it is good and getting power. if this is the case remove the toe kick at the bottom of the unit and find the 5/16 water connector at bottom left. disconnect it and call for water again, if it does not come out here your line or tank is frozen. if it does come out here it is frozen in the door and ge makes a kit for this which is easily insatalled if directions are followed
Posted on May 17, 2009
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
No water or ice
First thing to check is if the water filter is out of date, this will cause you not to get any water to the ice maker or the dispenser. Another thing to do is to get behind the machine and with someone pushing the dispenser see if the water valve vibrates. If it does and there is no water and the filter is good either the valve is bad or the resevoir inside the refrigerator is frozen and not letting water come through, but the last is unlikely due to the ice maker water supply does not go through the resevoir. The filter is the first place I would start with.
Sep 06, 2012 | Maytag MSD2456G Side by Side Refrigerator
Water pressure at dispenser too low
I am assuming with this answer that you have already checked your line tap from the water source to the fridge to make sure it is fully opened.
This is usually caused by an overloaded filter or a kinked hose.Some refrigerators use a large coil of ice maker hose placed in the Fridge box which acts similar to the older model water tank/resevoirs. The problem inherent to this cheap solution is that the hose itself has a narrow diameter hole which can freeze easily or become clogged with sediment. Check your filter first, them try removing your coiled hose if present and flush with water or air pressure.
Remember that heat rises and cold sinks, so it is quite possible that the resevoir/coiled hose has become frozen.
Mar 05, 2010 | Freezers
We just replaced the water filter...now dispenser doesn't work.
Looks like water is frozen in the tank .Unplug refrige from wall socket ,leave freezer and food compartment doors open at least 12 hours to melt frozen tank..
Jan 18, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice Maker and water dispenser is not receiving water. I installed a new filter to see if that was the problem, but that didn't help. I unplugged the water line going to the water dispenser under the door,...
first does the auger motor turn when to press the paddle for ice also does the light come on...and the beverage center is turned on ...if yes to alL then I would say you have a frozen water line or frozen water tank..if you have lights no motor, no water then you have a bad dispencer control board or main control... let me know if I can help anymore..
Sep 26, 2009 | GE Profile PSF26NGW Side by Side...
I have a friend with a Whirlpool ED5PHAXMB00. It's producing ice, and dispensing ice, but no water will dispense. She changes the filter evey time the light comes on, so am thinking it's not that. Have...
Some refrig's , water goes to filter first , some thru water valve first and then the filter . On this model , it goes to the water valve first , then the filter .
1) never change the filter just because the light says to . Only replace when icecubes get small or when water flow from dispensor slows . A filter can last 6 mths- 1yr. and sometimes longer .
2) the resevoir is in the refrig section , behind the lower crispers
3) the water valve is probably the problem
pt# 4389177
Sep 09, 2009 | Refrigerators
On my Kenmore model 106.74254400 refrigerator the water dispenser quit working. I push the button dispenser but nothing happens. The ice maker is working fine. Could it be the water dispenser switch?
It could be the switch. It also could be the resevoir is frozen behind the crispers. It could be the water valve has a bad coil. It could be a plugged filter if you have one in the line. Was the frig recently extra cold just before the problem? Check the resevoir first.
Eric
Jun 29, 2009 | Refrigerators
GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
In door water dispenser isn't dispensing water.
you did not say which brand, how old, or the model. But if your refrigerator is cooling properly..check the water resevoir behind the crisper drawers. It may be frozen up. I have seen this many times. You also have to check both soleniods on the water valve ( supply ) and the filter valve, if yours has a filter valve. I can't tell without model and make etc.
May 04, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Water/Ice Dispenser is not working
Some models need the filter inplace to pass water. First check it again with a new filter in just to be sure the filter isn't clogged. Next... do you hear any click or such noise from the rear of the unit when you push the water dispenser? The solenoid valves may be bad. Also check the valves at the back of the frige to see if the filter screen isn't clogged blocking water from getting into the frige all together. Let us know what you find and post again.
Dec 20, 2006 | Amana ASD 2624 Side by Side Refrigerator
GE GSS25VGMWW / GSS25VGMCC Side by Side Refrigerator Logo
160 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
