Question about SanDisk Sansa e260 MP3 Player
No more custom E Q
I had a prompt to got to recovery mode, found this site, someone helped out with that (thanks so much by the way) but now i don't have the option for a customized equalizer. did i do something wrong or do i have to live without now? please help!
I'm pretty sure the problem is that you didn't update the firmware. you should try that and see if it works.
Posted on Aug 29, 2007
Get a different mp3 player dont let it fool you it may look cool but it really sucks
Posted on Jun 05, 2007
I have a toshiba laptop I need reset without the recovery disk. Tech support said they could do it over the phone.. But I needed a credit card and I don't have one to use right now. Can someone please...
Let us ignore the bait and concentrate on recovering your laptop.
The recovery partition is still on the hard drive, use it to restaure the system:
Turn the computer off.
Press 0 and turn laptop on while maintaining pressure on 0 key
Once you see Hardrive recovery Mode displayed release the 0 key
Follow instructions on screen.
The recovery partition is no longer available or is corrupted
If your laptop is relatively new you can ask Toshiba product support to put you in contact with the company that sells the Recovery CD. They will need the laptop's serial and model number. The recovery CDs cost about 45 $ + applicable taxes.
You do not have a credit card: Use CASH.
Go to a store that sells the OS you are interested in. Buy the software. Should you need drivers, go to the Toshiba support site for your country of residence and download all that is available on the site that pertains to your Model number and your OS.
Aug 18, 2011 | Toshiba Tablets & eReaders
Bad Track
Change the Mode on the device and try to format again.
SETTINGS>MODE or USB MODE.
If that doesnt work. This will;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 19, 2007 | SanDisk Sansa e250 MP3 Player
Sansa mp3 player keeps turning on and off please help if someone has a solution
This should resolve it;
Best of Luck.
Nov 06, 2007 | SanDisk Sansa e250 MP3 Player
Recovery Mode
Recovery Mode doesnt help if you dont load anything.
Try this;
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Nov 03, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
I get - 'Load main image failed. Switch to Recovery mode'
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Sansa
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. If you have more questions, just add to this one. Best of Luck.
Sep 28, 2007 | SanDisk Sansa e250 MP3 Player
It won't start now!
Sep 22, 2007 | SanDisk Sansa e260 MP3 Player
Refresh database message
Run the recovery tool from the SanDisk website. Make sure you select format when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e260 MP3 Player
Load main failed switch to recovery mode
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 07, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
