Question about SanDisk Sansa e270 MP3 Player
E270 problem its stuck on refresh database
So i downloaded the file every 1 is linking and when idid it said error failure to read version. so i got no idea what 2 do
  • Anonymous Jan 12, 2009
    refresh database problem
  • chrishansgla Jan 20, 2009
    it dosnt recognize it....
  • 159 Answers
Download firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1449
download the new firmware for your player. After downloaded
install the new firmware and if you like check the box that says reformat data area.
Posted on Jan 15, 2009
How to recover deleted Microsoft SQL server MDF files?
Recover and repair MDF files with simple and efficetive tool to repair and recover MDF files from corrupt and damaged SQL server, which tool support all king of SQL server version and Windows OS. Visit here: http://www.en.mdfrepair.net
Read blog post: http://exchangerecovery.hubpages.com/hub/How-to-perform-SQL-Database-Recovery Corrupt MDF File Repair Utility
Apr 17, 2014 | Computers & Internet
Sansa e270 freeze if switch on,it indicates,REFRESHING DATABASE"
Having gone over a month with no response, I assume the reset solved the problem.
Jul 08, 2010 | SanDisk Sansa e250 MP3 Player
Frozzen on Refresh Database
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Oct 13, 2008 | SanDisk Sansa e260 MP3 Player
Refresh database
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 10, 2008 | SanDisk Sansa e270 MP3 Player
Stuck on refresh/black screen
Thank you
Computerrep
Mar 22, 2008 | SanDisk Sansa e270 MP3 Player
E270r Refresh Database error w/ version details error
Try putting the player into "msc" usb mode. "mtp" usually does that, but i've never hear of it being on the comp.
Good luck
Dec 17, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e270 MP3 Player has only 79 songs and 3 GB used
You may have some corrupt data on the device.
It sometimes creates the wrong file allocation and gives you an incorrect representation of the free space.
Try formatting the device in My Computer to erase all of the information and start over.
My Computer>Device Name(e270)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | SanDisk Sansa e270 MP3 Player
Refresh Database???
The application failed error means the you have a different version, not supported by this file.
You have a Rhapsody version.
You will need to contact SanDisk to have the recovery files sent to you.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Oct 16, 2007 | SanDisk Sansa e250 MP3 Player
Refresh database SansaDisk e270
Sorry, no habla espanol. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e200 MP3 Player
Stuck in refresh
Ok, I had the same problem and this is what someone else suggested to me and it worked so This issue could have been caused by file corruption or system errors on the device. We should be able to fix your player. Disconnect the player from the computer if it is connected. Please copy and paste the following link into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your Desktop. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Once you have downloaded the file, please follow these instructions. 1) Double click on My Computer so that you can see it on your screen. 2) Turn the player off. 3) On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange. 4) On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under "My Computer" called 16MB FORMAT. Once you see that icon you may release the Record button. 5) Double click the file you downloaded earlier and run it. Follow all of the on-screen instructions, and when you get to the prompt where it asks you whether you would like to Format it, choose Yes. Once it is done, click Finish. 6) Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left. 7) Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work. Now these steps worked for me I hope they work for you if it does email me at ericeconrad@aol.com
Jan 04, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
