You need to go into personal settings through the control panel on your computer and change screen settings for output 2. You may have to try different resolutions to fill the screen
use the 'format' button or 'size' button on your remote to switch between the different viewing modes. Keep in mind that if the show being broadcast isn't in a widescreen format you will either be stretching the image on screen sideways to fill, or you will be cutting off the top and bottom edges in order to fill the screen without any image distortion.
The picture size may have been changed on the remote. Try the button that says pic size or something close to that. It must have been switched to a mode which zooms in the picture. That should fix it.
press menu and move to picture settings and look for format or size if will have either (auto / 16.9 / panaranic / 4.3 displayed change it to full or 16.9
if there is a button on remote with aspect / zoom or format on it press until picture fill screen
Often there is an auto correct button on the monitor, if not them press them menu button and navigate to find horizontal size. If neither of those work you might try taking apart the monitor and reseating the video cable to the monitor.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
• 16:9 : Sets the picture to 16:9 wide mode.
• Zoom1 : Magnifies the size of the picture on the screen.
• Zoom2 : Expands the Zoom1 format picture.
• Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
• 4:3 : Sets the picture to 4:3 normal mode.
• Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
