Question about One For All URC-3021 Remote Control
Set up code
I need a Code I have a URC-3021B00
the TV brand Is a Sanyo CT-844
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): set up code - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Jan 08, 2009
I need codes for a seiki tv..I have a URC-3021B00
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 21, 2014 | Televison & Video
I have a urc-3021b00 and need to program it to a sanyo tv what is the code?
Hello;
According to the manual (PDF format) located at
http://www.hifi-remote.com/manuals/manual.shtml?URC-3021 (specifically Pg.20), the code for a Sanyo TV is 0154.
Try it and see. If it's not the right one, Pg.9 of the manual describes the procedure to find and check the codes for your particular device(s) using your remote.
Hope this answers your question correctly.
Mar 11, 2011 | One For All URC-3021 Remote Control
I need the set up code for urc 3021b00
One-for-All does not have a code list for the URC-3021b00. However, the basic code list and the manual programming method should be the same as the URC-3021.
Both the manual and the code list for the 3021 is available here: http://www.oneforall-na.com/remote.php?type=URC%203021 .
I hope this helps.
Mar 01, 2011 | One For All URC-3021 Remote Control
Code for remote
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Dec 08, 2009 | One For All URC-3021 Remote Control
How to program remote control urc-3021b00 please
Hope that helps.
Nov 15, 2009 | One For All URC-3021 Remote Control
Fine remote code for tv its a all for one urc-3021b00
I can help you with your URC-3021 Universal Remote Control issues.
Without knowing what brand of TV you would like to control, may I recommend using the URC-3021 One For All URC-3021 Code Search, or refer you to the Urc-3021 Code List?
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
One For All URC-3021 Code Entry
Urc-3021 Code List Download
Sep 30, 2009 | One For All URC-3021 Remote Control
I have a one forall urc-3021b00 and need the cods to progrm it to my t.v
need the code for my philips-magnovax t.v.you can reach me by phone 216-324-7744.my name is Cashmire Johnson.
Dec 01, 2008 | One For All URC-3021 Remote Control
I NEED CODES FOR TV DAYTEK AND HOW TO PROGRAM THIS
we have a 21" daytek hi def tv with no book or control. help?
Oct 31, 2008 | One For All URC-3021 Remote Control
Programing to a tv
Sanyo 0154 Toshiba 0154, 0156, 0060, 1356, 1656,
1704, 0650
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Aim the remote control at the TV and slowly alternate
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 16, 2007 | One For All URC-3021 Remote Control
One For All URC-3021 Remote Control Logo
160 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
