Question about PANDIGITAL (DPF802) Digital Picture Frame
I have a 7" Digital Photo Frame. It was working Christmas morning and now it won't even power on. I'm using the same wall pulg and will now power on using the remote or the power button on the frame
  • 6 Answers
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Posted on Dec 30, 2008
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Posted on Feb 11, 2009
robmcd27
  • 423 Answers
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
Posted on Feb 21, 2009
SOURCE: I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Posted on May 31, 2009
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
Aug 27, 2016 | PANDIGITAL 7" Digital Photo Frame With...
I have a siren digital photo frame that doesn't work. I have it plugged into my computer, but yet nothing happens. Also can't get it to come on when plugged into the ac power adaptor in the wall. Are
Take it back to the vendor if its new and does not work . costs a fortune to fix most times. Down load photos to a chip or use the camera chip, use the photo frame to display them.
Dec 24, 2014 | Computers & Internet
Why wont my digital photo frame turn on?
If you have not already done so, try another power adapter. In some cases, the cord between the power rectifier/step down transformer (the part that actually plugs into the AC outlet) and the connector at the frame end, becomes kinked or broken. The connector at the frame may also have become worn and not propely connected? If a second adapter does not work then the unit is faulty. Take it to your nearest service center for repair. (it may be less expensive to purchase another digital frame?)
Dec 20, 2012 | Philips 7008 8-INCH DIGITAL PHOTO FRAME
How do I install photos on my Sylvania Digital Photo Frame Model SFPF785?
Relax, you have over six months until Christmas. Just follow the instructions in the manual, especially with regard to the picture size and dimensions.
May 28, 2017 | Sylvania SDPF752 7" Digital Photo Frame
I need the users manual
Good morning, afternoon, evening or night; whatever time of day you are viewing this. Thank you for choosing FixYa to assist you with your request. Your request by the way, is the Pandigital 7" Digital Photo Frame with Interchangeable Frames User Manual? Listed below are some websites that may help you in your search.
http://docs.google.com/viewer?a=v&q=cache:8I4DKcVZOdoJ:www.pandigital.net/userfiles/file/Downloads/UG-E_PAN1502W02_v2_4_06-09-08.pdf+pandigital+digital+photo+frame+user+guide&hl=en&gl=us&pid=bl&srcid=ADGEESjacolvaFDh0RIYXkbHDg7Sw34HdtRG8AngSBiFF6fkYY7rVorAIU1F3IHiCD_4veyQK76_5VRzS3T3ycK9LDDRhyhqT9Ghmc97qJREgdmmtSVO9TFPIkdgJVD5Mv_OHDe9p2rt&sig=AHIEtbTMrjiZ6BI4kWajQ1kLFWujYdnskA
http://docs.google.com/viewer?a=v&q=cache:4Q6-8_Qb-cUJ:www.pandigital.net/userfiles/file/Downloads/UG-E_PAN3502W02_v4_0_06-10-09.pdf+pandigital+digital+photo+frame+user+guide&hl=en&gl=us&pid=bl&srcid=ADGEESih1x5vEA3fuucTtEItNLr6-6xPyrwDNShsUow0_RAj1BIEvhy2hMaQYPml9dbshMY7vqXr3U8aGdnOwhmRwbqhHaShSGFc0QlZcFzCcZ5aWZfTn4Yuk9IM4ZHxz22KCKMqGRBc&sig=AHIEtbRImJTFCCY1bYxd9aa_ZTOR3oZC8g
http://www.pandigital.net/?PageID=300
  • You will need to find your model number or frame size. Click download when you are finished.
  • The file may or may not download, depending on the file you chose to download .
http://www.retrevo.com/samples/Pandigital-manuals.html#Digital Photo Frame
  • You will need to find your model number in the links listed on the page.
http://camera.manualsonline.com/manuals/mfg/pandigital_dba_sourcing_network_sales_llc/pandigital_dba_sourcing_network_sales_llc_digital_photo_frame_product_list.html
I hope the suggested websites help you retrieve your manual. Thank you for choosing FixYa to assist you and please come back and visit us again the next time you need online assistance with a product. Thank you and have a good morning, afternoon, evening or night; whatever time of day you are viewing this post.
May 24, 2011 | PANDIGITAL 7" Digital Photo Frame With...
My children gave me a digital photo frame for Christmas. I have a Nikon digital camera. I have downloaded and deleted from my camera several pictures I would like to put into my photo frame. Am I able to...
If the "camera chip" you refer to is a removable SD Memory Card you need to put that into a SD Card Slot on your computer or use an USB Card Reader device. The computer will recognize the SD Card as a Disk Drive and you can use Windows Explorer to transfer the picture files to it.
Dec 29, 2009 | Coby DP-767 7-Inch Widescreen Digital...
Brookstone digital picture frame
The solution I suggest is to never buy anything from Brookstone again. I definitely will not.
Sep 11, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
PANDIGITAL (DPF802) Digital Picture Frame Logo
18 people viewed this question
Top PANDIGITAL Photography Experts
LP
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
