Question about Electrical Supplies
Need replacement jet inserts for Coleman Spa in Burlington, Ont
We have a warranty with Coleman Spas however the store we purchased our unit has gone out of business.
Need several replacement jet inserts for our Coleman Spa. We live in Burlington, Ontario.
Who would we contact and do you have a phone number and how much would it cost to replace the parts?
SOURCE: Marvin Model 3150 Electric Portable Room Heater
No I DID NOT GET A PHONE NUMBER TO CONTACT MARVIN MFG AND THE LINE IS BUSY. I DID NOT FIND THIS SERVICE, FIXYA, HELPFUL AT ALL.
I am not going to pay $29. or whatever for Expert Advice when you can't even give me a proper phone number to call the company. The heater didn't even cost that much. I can throw it out and buy a new one. What I ask for was not Advice but a PROPER PHONE NUMBER for Marvin Manufacturing and you could not even supply that.
Posted on May 23, 2008
  • 92 Answers
SOURCE: Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Posted on Feb 05, 2009
  • 56 Answers
SOURCE: air conditioner needs freon
If the system runs you will first need to add freon to the system (make sure it the right freon) Just enough to find leak. After you find leak and repair evacuate the entire system and weigh in charge. Hope this helps.
Posted on Feb 12, 2009
SOURCE: I have a Turboair Model K802R Range Hood. The
Bought a new part - You can now delete my email address - thanks
Posted on Jun 13, 2009
SOURCE: where can I buy a replacement battery?
I found a good deal on ebay. Didn't want to pay Dyson's battery price.
I love my Dyson handvac. I'm very happy to have it back again! The new battery solved the problem.
Posted on Apr 09, 2010
The light in our hot tub is not working..do you know how to install the new "clip" which we purchased from Beachcomber???
The light bulb just plugs into the fixture that is attached to the wires. Now, the fixture is installed from the back of the white niche by inserting it and giving it a quarter turn to the right. Next time you need a bulb, for a few extra dollars more you can upgrade to a color changing LED bulb. Find one at poolsupply1.com
Nov 01, 2014 | Pool & Spa
Eng 1 code
Hi, if you are seeing an EN-1 code, there isn't any troubleshooting that can be done to resolve it. This code indicates an electrical issue internally, the Power Pack is unable to register the temperature of the water. The unit will need to be serviced. Please contact Oceantis at (855) 772-6269. Oceantis is the only authorized service provider for all of Comfortline Products Spas in North America. Portable Spas Accessories Parts and Chemicals Oceantis Oceantis Cape...
Jul 09, 2014 | Comfort Line Spa 2 Go Portable Spa with...
Morgan spa diagrams
The water jets in most spas are adjustable so you can turn the water flow down to just a trickle if you want to.
You don't take current spa jets out of the spa. They are held in place by a couple of tabs. Through the years the chlorine/bromine will deteriorate those tabs and the spa jets will start "popping" out when the jets get turned on.
If you pull the jet insert out the socket they are in, you will ruin the jet insert and it will need to be replaced.
Rod
US Parts Center Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 13, 2014 | Pool & Spa
Water doesn't heat up anymore
try heating the spa with out the filter. if it heats and you've cleaned your filter, replace the filter. if it doesn't heat and you have good water flow you need to replace the heating element.
http://www.dpbolvw.net/click-7782383-11139284-1413480001000
Aug 22, 2013 | Therapure Four Person Inflatable Round Hot...
En2 error code
Hi, if you are seeing an EN-2 code, there isn't any troubleshooting that can be done to resolve it. This code indicates an electrical issue internally, the Power Pack is unable to register the temperature of the water. The unit will need to be serviced. Please contact Oceantis at (855) 772-6269. Oceantis is the only authorized service provider for all of Comfortline Products Spas in North America. Portable Spas Accessories Parts and Chemicals Oceantis Oceantis Cape...
Aug 20, 2013 | Comfort Line Spa 2 Go Portable Spa with...
Dream Maker Spas leak
This means one of your top jets is leaking. Firstly try Fix A Leak this will stop any leak up to an 1/8". If this does not help there will be more difficult work in store.
Each jet sits in a jet body, these jet bodies are behind the tubs shell, you'll need to get in behind them to see which one is leaking. This can be difficult as they are often covered in insulation foam.
Sep 05, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a coleman emerald 455 hot tub and I have managed to lock the electronic control panel. How do I unlock?
press program and then mode, it will display "0" and will be unlocked. u locked it by pressing program twice
Nov 05, 2010 | Pool & Spa
I bought a home and my coleman spa 400 series has a problem, the jets 1 don't come on, jets 2 do. the water isn't heating up. was wondering what the problem could be
Pump one is the pump that does all the work in your spa. It handles the heating and filtering. If pump one does not work, It will not heat. It is likely pump one is gone but a technician would be needed to determine if it is the pump or the spa pack.
Dec 23, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
I need an owners manual for a Coleman Spa Horizon series 447
Chuck, did you find the manual? If not I have one with my spa maybe I could copy it for you.
Ron
Sep 04, 2009 | Coleman Sport & Outdoor - Others
Electrical Supplies Logo
703 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
