Question about HP Officejet 5610 All-In-One InkJet Printer
Doesnt print i just put in new print cartidages. and now the jobs that go to print. say queue, like if their paused.
    Scholar:
  • 105 Answers
Hello.
Turn off the All-in-One, unplug the USB cable of the printer from the computer.
If u are using XP, click on start>>run and then enter "services.msc" in the run window and then hit enter.
the services window will open, and from the right panel of the services window, select the print spooler, right click on it and then select restart. (Make sure you close all the open windows on your computer). close the services window and then plug in the USB cable of the printer back to the computer and turn on the printer.
The issue must resolve.
Update the thread with the results.
Thx
Posted on Jan 08, 2009
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
Feb 20, 2015 | Canon imageCLASS D320 All-In-One Laser...
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Printer was working, but is not now. All cables are hooked up properly and have been disconnected and reconnected. I have several documents in the memory to be printed, but the printer will not respond. ...
Here are four things you can try; may not have to perfom all:
Check to see if your printer is off-Line
1.Open the Printers, Printer and Faxes, or Device and Printers folder.
To do this:
Windows XP users; Click on Start > Settings > Printers an Faxes or Start > Control Panel > Printers and Faxes.
Windows Vista users; Click on Start > Control Panel > Hardware and Sound > Printers.
Windows 7 users; Click on Start > Device and Printers.
2.Right-click on the printer object (icon), and select Use Printer Online.
3.Microsoft Windows 7 users will double-click on icon, select printer and then de-select Use Printer Offline.
Printer Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation:This is typically an end user error. Hint: Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do:
•Double-click on the print queue icon to open the print queue.
•Click on Printer in the upper left-hand corner of the menu bar.
•Is there a check mark next to Pause Printing?
-If yes, click on Pause Printing to turn off this Windows feature.
-If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Delete print jobs from the print queue
Access the print queue.
Delete all print jobs
• Click on Printer in the toolbar and then click on Cancel All Documents,
or
• Right-click in the print queue and select Cancel All Documents from the pop-up menu.
You can also delete individual print jobs
1.Highlight the individual job in the print queue by clicking on it.
2.Right-click on the highlighted job and select Cancel from the pop-up menu.
IMPORTANT! If a job is stuck in the print queue and cannot be deleted or canceled using the above steps, there may be an issue with the printer spooler that controls the printing options in Windows. If you observe this symptom, it may be necessary to stop and restart the print spooler; then retrun to delete print jobs.
How to Stop and Restart the Print Spooler
Problem:
Unable to cancel print jobs; Unable to print; Print queue is unresponsive; Locked print queue; Unable to print; Cannot cancel print job; Printer driver not responding
Solution:
The print spooler controls print options within Windows. A problem with the print spooler can affect printer driver performance and Windows print queue responsiveness. Stop and Start the print spooler to see if observed symptoms subside or remain.
Method 1: Using Administrative Tools
Step Action
1 Click on the Windows logo start button.
2 Click on Control Panel on the right-hand side of the start menu contents.
3 Click on Maintenance.
4 Click on Administrative Tools.
5 Click on Services. NOTE: You may have to provide an administrator profile and password.
6 Scroll through the list and look for Print Spooler.
7
The following two options are available to stop and start the print spooler:
•Click once on Print Spooler to highlight it, and then click on the Stop or Start links in the right-hand window pane,
or
•Double-click on Print Spooler, and click on the Stop button followed by the Start button.
8 Observe the status column in the Services window to verify that the print spooler is stopped or started as applicable.
Trust this helps to resolve your problem. Please vote.
Dec 29, 2010 | Lexmark X5495 Printer
My printer won't print. it sends the jobs to the "queue" but doesn't do anything. what do i do?
First of all whatever jobs u have sent to the queue ... pause it and go to services.msc and stop the print spooler services ... minimize the page and delete the print jobs from the queue.... go back to services.msc.... restart the print spooler services..... if that does not work .... follow the detail link : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&cc=us&lc=en&dlc=en&product=1138342
Apr 19, 2010 | HP Officejet 4315 All-in-One Printer
I'm unable to delete a job from the queue. And therefore, I'm unable to print anything else. Any ideas of what to do? Thank you!
Open the print Queue, click the print job that is hanging and then from the menu, I believe under file, click pause. Once it is paused tried to delete the print job.
Sep 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
My printer doesnt work, i just put in new ink cartidages and now my jobs say that their on pause . it doesnt let me click resume to make the jobs start.
I've just installed two new print cartridges, and they have been aligned and it goes through the motions of printing, but no ink comes out. Is their a solutionto this? It was just working two days ago.
Thank you.
Jan 08, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
