Question about RCA DRC310N DVD Player
No Color with S video
There's no color reception with S video cord, black & white only
ctf1800
  • 4402 Answers
SOURCE: color went out
what do I need to do to get the color back on my t.v.>>
get rid of boy friend! problem fixed!
sorry i just could not resist!
doesn't this set have Auto color balance resets individual picture tube guns (red, green, blue) to maintain consistent overall picture quality for the life of the tube.
Posted on Dec 14, 2007
  • 108 Answers
SOURCE: RTD 155 - only black and white...no color
Perhaps you have set your DVD player for Progressive Scan Mode while your Television does not support for the same. Go to the setup menu and turn Progressive Scan Off. This will solve your problem.
Posted on Feb 04, 2008
  • 4234 Answers
SOURCE: Have an RCA console, color, 26
If you can see white, then all the CRTs are functioning. Make sure that the channel is set correctly. If the DVD is sending out channel 3 and the TV is set to channel 4, you will see the picture, but in B&W, Check that first. Let me know if that does not resolve it.
Thanks,
Dan
Posted on Mar 06, 2009
joez47
  • 61 Answers
SOURCE: RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Posted on Sep 13, 2009
  • 15 Answers
SOURCE: color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Posted on Jul 23, 2010
Lost color
It could be the color processor module, could be locked up, or your tuner is going bad. First thing to do is unplug the AC cord, from the the AC outlet for about 40 Minutes and that will reset the color processor. if you still have problems, then bypass the tuner, and go directly to the video input with a DVD player, or Video game player "360 x box" or anything that you can hook up to the video input. Make sure to put your TV in Video mode, if you have color now , than you have a bad tuner, if it is still black and white, than in is the color module that is bad, or your color control is turn all the way down.
Mar 23, 2014 | Samsung HLN437W 43" Rear Projection HDTV
Hitachi 50V500 black and white only
Not sure what kind of video hookup you're using.I'm guessing you are using a red/white/yellow audio/video cord.If you plugged the yellow(ccalled composite) cord into the green of the component video port,it may look like black and white.(this can be a fun prank to play on someone who annoys you).
Jun 13, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
JVC AV27S33 tv black and white
I would guess you are using an antenna or a cable service without a set-top box.
When the TV is using HDMI or component video it does not employ the decoding for the color as like when using an RF feed. Most people of today do not use RF directly in to their TV set using the built in tuner. They feed a desk-top box that feeds a decoded picture in to the set via the component RGB connectors, or they are using HDMI.
When viewing an RF signal from the antenna or cable using the TV's internal tuner, check the video settings. make sure the setting for Color is turned up to 50% of its range to start with. If there is no color, check to make sure the Settings are correct. Check to see if the TV has a black and white mode, and this mode is turned on.
Check to see if the TV receiver section is for your location type. If you have a set from another country that uses another broadcast system for color this can be an issue.
It is also possible the TV set's color decoder for RF reception is defective. This would require proper service. You would not be able to service this yourself.
Based on the info you supplied these are the best suggestions I can think of...
Mar 11, 2017 | JVC AV-27S33 27" TV
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
How to hook up a cord to the maytag neptune dryer color codes
these are single phase so just copy red to red black to black white to white and green is ground
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Canon powershot A85 camera, only seeing black and white on TV
Please check Yellow video connector in TV and hook camera video cord there to see color picture of Canon A85
Feb 20, 2009 | Nikon Coolpix 5600 Digital Camera
Black and White instead of color
Assuming you are using the VS-2 with your system. I have experienced the same problem when I fiddle with equipment. Each time it is due to the S-video plug from the VS-2 cable becoming loose or detached. Make sure every cord is re-inserted into the back of the LS 38.
Dec 07, 2008 | Bose Lifestyle 48 System
Make sure both S-video (black round connector) and Composite video (yellow connector) are connected to video outputs not inputs. It can also be the S-video is disconected, that will give you a black and white picture. FR
Nov 30, 2008 | Bose Lifestyle 28 System
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
RCA DRC310N DVD Player Logo
23 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
