Question about Emerson MW8102SS 1100 Watts Microwave Oven
Can't use the microwave at all
The clock works but I can't use the microwave.It won't turn on or heat up food.It doesn;t do anything.
  • amarie9090 Jan 09, 2009
    I have the same issue. It counts down but it won't heat up. Could this be because of a surge in power? Like if the circuit breaker was flicked on and off to the outlet it was plugged in to? Would that blow something and make it act like that?
  • lmostrander May 11, 2010
    the clock works, keep time -no problem with that.
    What do the indicater lights mean-- It is not in the manuel
    this ist red small light turns on
I have emerson mw81195bm microwave doesn;t work
Posted on Oct 22, 2012
    Sergeant:
    Champion:
  • 338 Answers
You have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Posted on Jan 08, 2009
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: How to fix an Emerson microwave 8992RD that
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on May 08, 2011
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
The microwave turns on but does not heat food. i reset the microwave by unplugging it for 2 minutes. once plugged back in, i reset the clock. i made sure the unit was not in demo mode. it still does not...
A part called the magnetron tube supplies the microwaves which heat your food. It's possible the tube has gone bad. It's also possible that other problems are keeping the proper power from being applied to let the tube work.
Microwave ovens use hazardous voltages WHICH CAN KILL YOU, so troubleshooting is best left to professionals with the tools and experience to work on them safely. If this is a basic counter-top oven, it may be more economical just to replace it. Otherwise let a qualified technician determine what has gone wrong and give an estimate to repair.
Sep 02, 2011 | Microwave Ovens
We have a sunbeam microwave. it starts but the light doesn't work and it won't heat the food. what should we do?
heatman101 ;'
Sep 01, 2011 | Sunbeam SMW750 Microwave Oven
Microwave Model (1992) J KP6460P1B6 Doesn't heat food. Timer, clock, etc. work fine.
heatman101 ;'
Aug 25, 2011 | Microwave Ovens
The microwave turns on but does not get hot. The light is on, the the clock, the timer and everything works, except that the food does not get hot. I tried to heat up some water and doesn not change its...
you need to remove the outer cover,then carefully discharge the high voltage capacitor with 2 insulated screwdrivers or an insulated jumper wire,then test this and the high voltage diode and the internal ceramic fuse for continuity
Nov 15, 2010 | Amana ACO1860 Microwave Oven
Does not heat food
It could be 3 problems. 1. the part that spits out the microwaves needs replacement, door hinge switch is broken, or circuit board need replacement. First check with Whirlpool and see if it is under warranty still. Call a repair man. See www.repairclinic.com .
Mar 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
570 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
