Question about Canon ZR100 Mini DV Digital Camcorder
Tape wouldn't eject, now power unavailable.
I dropped the camera 7 inches onto carpet when the tape door was open. I put in a tape and pushed down the black part, and before the motor closed the tape, it slipped out of my hand. First the tape wouldn't come out, and it kept beeping saying 'remove the tape' but it wouldn't come out. Now I can't even get the power to come on with batter of adapter. Please help. How do I get it back on and get the tape out.
  • Anonymous Mar 27, 2014
    Camera beeped, went t a white screen and then powered off. Since then, I can't power up the camera, even to remove the tape.
  • 883 Answers
Open it. find the motor that activates the tape door. turn it by hand until tape is fully exposed to be removed.
Posted on May 31, 2007
How do I load the tape
I see your picture of a cassette player. Guess you are referring to that. (tapes also come in reel-to-reel, and 8-track). Just push the "EJECT" button (power may need to be applied to some units for the eject button to work). The tape slot will open. Insert tape with exposed tape on the "head" side of the opening, usually the heads are on the bottom of the slot.. You can't put it in any other way and have the door close. The "door" that opens has guides for you to slide the tape into. The side you want to listen to should face you. Either manually close the tape compartment or push the close button (depending on model). If the door doesn't close, you put it in upside down. Push play and enjoy.
Oct 01, 2014 | Audio Players & Recorders
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Panasonic Palmcorder PV-43D cannot get door open
Hi there.
Sometimes a gentle slap with the palm of your hand with the door facing towards the ground does the trick, make sure you power it off then on press eject while you gently slap it.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Canon ZR85 camcorder won't turn on
Steps for removing the tape from a totally dead ZR85:
1. Turn camera upside down.
2. Move "Open/Eject" button to full right position (toward lens).
3. Manually push tape door open.
4. On the metal surface that sits between you and the tape, there is a very small screw. There is probably a yellow sticker next to the screw that says "Do not press on this part". With a small jewelry phillips screwdriver, remove that screw.
5. Push the metal plate (with tape) in the direction ofr the door and lift slightly. The metal assembly holding the tape comes loose, exposing the top of the tape.
6. Pull the tape upwards (out of the camera). At this point, the tape will still be engaged in the play heads. With the cartridge out far enough to see the heads, reach in with your jewelry screw driver and carefully lift the tape over the heads, and free from the camera.
7. Use the eraser on the end of a pencil to wind your tape back into the cartridge.
8. When re-assembling the mechanism in the camera, there are two curved slots on both sides of the piece you took loose. You'll need to thread these onto two posts inside before you place the top back in position and put the screw back in.
May 10, 2008 | Canon ZR85 Mini DV Digital Camcorder
Tape mechanism
This sounds bizarre I know, but I read another threat regarding Canon camcorders and tapes self ejecting. The advice was to ........ wait for it........ drop it onto a carpet floor from about 1/2m. My wife top me not to consider it. I continued reading and someone else had been successful using the technique. I have to report that it actually works. I dropped it (twice for good measure) and it loads tapes once again. Its true what they say, if in doubt....give it a clout!!!
Mar 19, 2008 | Canon MV750i Mini DV Digital Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Canona Elura 60 problem...
What a hunk of junk. Not a month after the warranty period expired, my Elura 60 would zoom out without warning and refused to stay zoomed in. I paid Canon to fix that problem.
Now, I'm on vacation (in the Carribean for more than 24 hours) and the unit wouldn't accept a tape. Every time I tried to load a tape, it would beep five times and then kick the tape out. So I tried taking all of the batteries and media out. That didn't work.
Next, I tried the drop method. I figured the unit is broken and I'm not going to pay again to get it fixed, so dropping it couldn't break it anymore than it already is. I let the unit fall onto the throw rug in the bathroom. In then tried to install a tape. Waddyaknow! It worked.
I can only reiterate again two things: dropping the camera from about 6" onto a carpeted surface over a tile floor seemed to clear up my "remove the cassette" problem, and the Elura 60 is a temperamental hunk of junk (although the recordings and playback are pretty good, when you can actually get a tape into the unit).
Nov 12, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Eject
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
1. Remove the two small screws from the tape door face. I show the entire carriage removed.
2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage.
3. Using something small push down on the peg to release the tape door.
4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
Good luck, hope this helps everyone,
Apr 21, 2007 | Canon ES900 Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
290 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
