Remote not working
Our remote has suddenly stopped working. We changed the batteries but it still will not turn on our system.
  • 2,071 Answers
There are two causes of remote not functioning, first the eye of the remote is loose contact you must resolder it so it become firm and second the crystal it is a square shape look a color of yellow or blue with the number 500,512,513 whatever the number you have replaced it with identical number.To check the remote if working or not ,try to get a cellphone with camera ,then open the camera then align your remote under the cellphone then push the button of your remote see to it,if it glowing in the camera when you are going to push remote button,if it is glowing then your remote is fine if not then still defected. Try this to find the result.
Hope it may help you;
Regards;
VOTIT
DON'T FORGET TO RATE
Posted on Jan 08, 2009
My comcast remote was working with my Motorola dct700/us box and now suddenly stopped working
Put in new batteries or check that the battery contact points inside the remote are free of rust or acid build-up from leaking batteries.
Dec 06, 2013 | Arris DCT700 DTV Receiver
Dash lights stay on
need batteries or new remote and there are a few autos if a brake light bulb goes out inside light stays on to let you now maybe dash light on others because you cannot see your own brake lights
Mar 01, 2013 | 2004 Chrysler Pacifica
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Jul 02, 2012 | Hunter 27185 Remote Control
Akai KC02-E1 Remote with new batteries stopped working.
First, You cannot resync the remote, Second the IR sensor may be bad on the tv and third, the Digital bd may be bad. The IR sensor connects directly to the Digital bd which is the brains of the tv. Also, there maybe a stuck button on the remote or the buttons on the tv.
Jul 13, 2009 | Akai PT4298HD Rear Projection Television
Remote key lock stopped working after wal mart put new battery in and now my head lights stopped workin!!!
check fuse for low beam, then possibly both low beam globes. they could have blown.
the key remote may need reprograming into system try put key in ignition in on position then press remote buttons a couple of times then try if no good need to go to dealer to be programed into system again or it needs repairing/replacing.
May 31, 2009 | 1996 Chevrolet Camaro
Remote stopped working
clean the circuit board on the remote moisture might be the problem
Aug 14, 2008 | Philips DVD750VR DVD Player/VCR
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
