Stinky towels We wash our towels, and they come out smelling fine. When we dry off with them they stink like mold or something. We have even changed towels, and the new ones did the same thing. We don't know what to do. Please tell me how to clean out the washer or something. Thank you for your prompt response. I have a LG front loader washer and life is not good, clothes were great first 6 months, then all of a sudden awful smell in washer. Cleaned filter and drained water as required, left door open, dried rubber ring and glass door, use HE Tide, used soda, used vinegar (helped slightly) Still when towels get wet they smell mildewy, gross, awful smell I am just sick of it after spending that kind of money. Can anyone help?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
Unfortunately this problem can occur with all front loaders made by any manufacturer. The problem results from excessive soap and body oils that do not fully dissolve and/or rinse clean from inside the inner and out tubs. Front loaders are energy efficient and only use a little water so any build up between the tubs that gets higher than the water level is left behind. It is also natural that some moisture collects between the folds of the door gasket and, if not wiped out, will mildew over time.
Not to worry, a few changes in use (as compared to top load washers) can easily eliminate your current problem and keep it from returning.
First of all, make sure to ONLY use HE (high efficiency) detergent and make sure to use no more than 2-3 tablespoons per load (because too much detergent will cause oversudsing, not break down efficiently and build up between the inner and outer tubs).
To eliminate the problem you now have I highly recommend a product called Whirlout (available at Home Depot in the hot tubs section). Just one capful in an empty load with the hottest water cylce will break down the current build up and take care of any odors (a 2nd cycle if the problem is really bad).
To avoid any problems in the future, use the correct amount and type of HE detergent, wipe the door gasket dry when done with the laundry (for the day, week or however you do your laundry) and run an empty cycle once a month with a capful of Whirlout. If your machine is in a high humidity location (i.e. a basement), then leave the washer door cracked open when not in use.
Hope this helps, please rate my answer.
Posted on Jan 11, 2009
Kenmore washer mold smell issue
front loader of top loader? For front loaders you need to dry around the front gasket and leave the door open 24 hours after each wash.
Put a couple of towels in the machine and add a full box of Arm and Hammer Baking Soda and do a 90' boil wash. Clean towels and the smell gone.
Jul 17, 2016 | Kenmore Washing Machines
Where is the filter on the series 70 washer? my washer has a stinky smell and someone suggested it may be a filter that needs to be cleaned.
clean the door boot carefully with bleach if mold grows in the lower door drain holes it will mold and stink,you will see black spots on the boot,thats mold
Sep 11, 2011 | Kenmore 24032\24036 Top Load Washer
Musty smell especially in towels
Once towels have had mold grow on them, it's unlikely you will ever get rid of that smell. You can usually tell a towel has had mold grow by discolorations on solid color towels. You probably need to start over with new towels, make sure they are washed and dried frequently and that they don't stay damp for long after showering. If you live in a humid climate, a towel warming rack will help with drying.
Jul 21, 2009 | Fisher Paykel EcoSmart GWL15
Washer stinks - smells like mold or mildew
You have to kill the mold. To do that mix one cup of clorox liquid bleach into one quart of water and wipe all aroung the rubber. Let it dry and do it again. That will solve your problem
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
STINKY CLOTHES
detergent ??? yo are using a HE detergent correct??? foul odors can be attributed to over soaping in clothes this may be a real problem if not and even then you ll need to dramatically cut down on the amount of soap you use.. oneway to determine the "oversoaping " is to take a recently washed sock from the drawer and place it in a cup of water , with oyur fingers agitate the sock up and down in the cup and see of suds form if theres your problem.. this was posted no to question yor laundering techniques, or to be a smarta**, but oyou didnt mention you detergent so just wanted to rule this out.
Mar 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Towels smell oily and moldy--really stink
Don't use fabric softener. I had the same problem and read somewhere to stop using the fabric softeners. I don't know why but after about two cycles (they smelled really bad) it worked! I always used fabric softeners with out a problem but one day I just started getting REALLY smelly towels. I always take my wet wash out as soon as the cycle ends and dry it completely so I was surprised when they smalled so bad. Give it a try.
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Jun 21, 2008 | Asko W6221 Front Load Washer
Whirlpool Duet Sport? Front Load Washer WFW8300SW
hate my duet sport also! You cant presoak in this machine, very little water to wash with, very noisy, and everything stinks when it comes out of washer. Mine also smelled like mold but i figured out if you pull out the little tray that holds the detergent it is filled with stinky black mold. would never buy again
Jun 18, 2008 | Whirlpool WFW8300SW
Stinky Washer
We had the same problem with our front loader. (after only a year) We ran a load on "sanitary" setting with bleach. After that we leave the door open after EVERY load. That has fixed our problem
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Stinky towels
I will continue to post this to everyone in hopes that enough people will add their voices to mine.
What is the mater with us that we are accepting this outrageous product flaw?
Let's put the blame exactly where it belongs and keep it there until manufacturers clean up their act!
What in the world are we thinking when we allow ourselves to be forced to jump through these ridiculous hoops just do do laundry!?
I am furious and it is over something as stupid as a washing machine! A WASHING MACHINE!!!!
The new government regulations for new water efficiency washing machines has my family’s clothing smelling like a stinking, rancid, moldy basement! This is absolutely absurd! I have been told to change laundry detergent, run hot bleach water through my washer and, get this; my washing machine is 1 year old and my clothes smell filthy!!! The mold and mildew from these nasty machines have wreaked havoc through skin rashes and allergies in my children!
I paid $1,000.000 for this da*ned washing machine and THIS is what is being sold to the public under the disguise of efficiency!!?? I have been on the phone about this problem. I have, over the past 3 months, with a technician on the phone, been instructed to do the following:
*Make sure I use high efficiency detergent THAT will fix my problem.
Wrong.
*Cleaned the lint trap (..that is stupidly behind a metal access plate that you have to use a screwdriver to remove screws to get to it EVERY TIME) and THAT will fix my problem.
Wrong!
*Cleaned the water hoses; THAT will fix my problem.
Wrong!
*Cleaned the gasket around the door. THAT will fix my problem
Wrong!
*Cleaned the tub with bleach water. THAT will fix my problem.
WRONG!
*REMOVED the hoses and cleaned the pump. THAT will fix my problem.
WRONG AGAIN!
*Take the pump out entirely and clean all inlet, outlets and hoses. THAT will fix my problem.
WRONG! WRONG!! WRONG!!!
NONE of this fixed my problem of filthy, wet, stinking, rancid clothing that has endangered my family's health! I even washed my children's clothing out by hand in the bathtub and put them in the washer just to rinse and spin and they STILL smelled horrific.
Finally, at the end of my rope, I returned to the appliance store from which I purchased this machine and they have told me that they cannot accept a return. They will not accept a return and I have to deal directly with GE. I HAVE dealt with GE up until the final straw when I they told me I needed a new pump, but so sorry, your warranty JUST expired 3 days ago!!!
Furthermore, my pump was fine. I did NOT need a new pump and have now been told that I cannot return the new, unused pump that cost me another $183.00. I have now been told that this is a problem with ALL front loading washing machines and I should do the following:
*First, run a full complete wash cycle on hottest setting containing Bleach – * Note: wash cycle takes 1 hour and 20 minutes
*Next, run a full wash cycle on hottest setting using high efficiency laundry detergent for another 1 hour and 20 minutes
*Next, run a full wash cycle on hottest setting using Cascade automatic dish washing detergent for an ADDITIONAL 1 hour and 20 minutes
*Next, using Bleach water, wipe down entire interior of washing machine
*Next, using clean white cloth, wipe entire interior of washing machine dry
*Next, leave door ajar to air out machine
*Finally, I have now been informed that I cannot use fabric softener in the machine even though there is a fabric softener dispenser right in the machine because the new front loading machines cannot handle fabric softener!!
Furthermore, I was told that this is new technology and since it is so new, no one really knew these kinds of problems were going to manifest themselves and I just need to try to work with these problems because it is not the manufacturers fault but the GOVERNMENT’S fault! Sorry.
Are you kidding me??
Now I have a $1000.00 piece of junk that the appliance companies are pawning off on unsuspecting consumers and hiding their horrible designs by blaming the government.
So, now this is what I want!
I want the legislature to force manufacturers to properly inform the public of these problems and those who did NOT inform consumers of these issues, COMPENSATE their customers for the $$$$$ it has cost us and the misery and frustration caused by THEIR neglect by NOT informing the consumers of these issues. I want this to be retroactive BACK to at least the year 2005. Furthermore, I want compensated for the cost of buying a top loading washing machine in an effort to keep our families away from the mold and mildew and filthy mess this has caused! Finally, I want manufacturers to own up to the fact that they disregarded the health and safety of consumers in their efforts to profit as much as possible while touting efficiency.
Now I have heard that they have a new 'product' they can sell to us to inhibit the stench of mold and mildew. This is absolutely unacceptable!
This is outrageous and we need to speak out about this and make sure our voices are heard!
Apr 15, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
728 people viewed this question
Top Washing Machines Experts
