Question about Cobra 29 LTD CB Radio
What is the number on the pot next to the final that i have to turn out?
  • Louie  Role
    Louie Role May 11, 2010
    Hi and welcome to FixYa,
    Offhand the only "pot" near the final would be VR5, but that is used the S/RF meter. The other would be VR4 used to limit/increase modulation.
    Good luck and Thank you for using FixYa.
    Brigadier General:
  • 6,966 Answers
Posted on Jan 10, 2009
How can I fix my 55 cup Farberware coffee urn FSU 255 model and it won't turn on. Any suggestions? It's always worked well before--this is a new issue.
If it will not perk or even get warm, the main heating element (usually in the middle of the pot) is probably bad. Get an ohm meter and read the resistance directly at the pot terminals (looking into the pot) (before taking the pot apart). If you get a infinite reading (or in the thousands of ohms), the perk heating element is probably bad. On my small pot, that element appears not to be replaceable...but pull the base off and see.
If you pull the base off, you will likely see three components; main perk heating element in the middle of the pot, "keep warm" element - may be covered in braid) skirting the edge of the pot, and finally the thermostat that allows the pot to perk for 7 minutes then opening up the circuit to allow current to both of those elements in series just to keep it warm.
Although I don't have a pot exactly like yours, in my smaller pot, the "keep warm" element (covered in braid) and the thermostat (little button pressed by a spring and screw against the bottom of the pot to sense temperature) can be replaced...go to Goodmans.net.
Jul 23, 2014 | Farberware Coffee Makers & Espresso...
I have an air leak in intake line
Question:
What do I do if my pool/spa pump is loosing suction or prime?
Answer: by Osko Pool n Spa Pool Pump Losing Suction or Prime If your Swimming Pools Filter system looses Prime, it is caused by one of the following conditions.
Note: The lost of suction/prime is caused a leak which in turn sucks air into the system. The lost of suction/prime will be anywhere from the Main Pool Skimmer(s) to the Pool Pump. It will NOT be from the Pool Pump to the Pools Main Return(s).
1) First make sure that your water level is high enough so that the skimmer is not sucking air.
2) Check the Pump Pot Housing Lid Seal and be certain that its completely sealing and is not
Sucking air into the system. Check the lid for cracks. If either condition is true, replace the Pump Pot Lid Seal and/or entire lid
3) Check all fittings, clamps and hoses from the pools skimmer to the Pools Pump Pot Housing for wear, tightness and leaks.
4) Check Pool Pump Pot Housing for cracks.
If everything aforementioned in good working order, the next thing to check is the Pump Pot Housing Main Seal and the Pumps Impeller and finally the pump.
5) While the Pool Pump Motor is running, carefully inspect the area where the Pump Pot Housing attaches to the Pump Motor. See if there is any water leaking. Next, spray the area with water and see if the water is sucked into the Housing. If so, your Main Seal is damaged.
6) Disassemble the front half of the Pump Pot Housing from the back half and inspect the Pump Motor Impeller. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged.
7) Re-inspect the Pump Pot Housing Main Seal by standing the partially disassembled upright, with the Pump Motor towards the ground. Pour water over the impeller and into the cavity. See if the water leaks thru to the outside of the Pump Pot Housing. If so, your Main Seal is damaged.
8) Remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged.
If everything seems to be in good working order, then you need a new pump... not just replacement parts
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 18, 2013 | Hayward SAND FILTER, PRO SERIES
In turning up volume on eon g2 15 I get crackle sound and then when I mess with switch it finally works. The speaker has been used probably 10 times max. Its not a cord problem..perhaps its the control?
This model has very cheap pots. What really happens is the center pin on the pot breaks leaving the wiper that rides on the carbon track to lift, causing this problem. Use caution as this condition continues the pot will go bad enough to send max volume to the system causing severe damage to the speaker, and maybe the listener. THE GREAT OZ.
Aug 08, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
We lost the game instructions to Hey Hey Witch Way.
Hey Hey Witch Way is for 2-4 players.
Game set-up: Select a game token each. Divide the Lucky Gold Pieces (LGPs) equally between the players, and have each player place two pieces on the Pot of Gold space marked at the end of game board, and one on the Witch's Treasury at the top of the Magic Mountain.
Weird Woods: Use the spinner to determine how many squares each player moves in their turn. The green lines with black dots are hedges; you can't cross them, but apart from that each player may choose what path they take. More than one player may be on a square at the same time. If you land on a "Pay One" square, you pay a LGP to the Witch's Treasury at the top of the Magic Mountain. If you land on the "Take Two" fairy, you take two LGPs from the Witch's Treasury. When you get to the end of the woods, you take position on any of the four arrows at the bottom of the mountain.
Magic Mountain: Instead of using the numbers on the spinner, this is where you need to use the colours. Spin the spinner. If the colour it lands on is on the next level of the mountain, you may move to it. If not, you miss a turn. Only one player is allowed on each space at a time. If you land on a "pay witch one" space, pay a LGP to the Witch's Treasury. At the top of the mountain, you must spin a 6 to enter the Treasury, and the first player to arrive takes any LGPs in the Treasury.
To the Dungeon: "Pay One"s and "Take One"s from here on are to the Pot of Gold at the finish, and players may share the same spaces. Before taking their next turn, each player must state whether they opt to go round the circle first next or head straight to the trapdoor. Landing in the trapdoor is a "miss a turn", and you must spin the exact number to arrive in the dungeon.
Escaping the Dungeon: On arrival in the Dungeon, each player must choose and announce which escape route they opt to take, and spin the appropriate number to enter it (the Rope would require spinning a 1, and the Ladder a 2, for instance). Once into their escape route, players proceed to the Monster Moor.
Monster Moor: Travel through the Moor using the numbers on the spinner to determine rate of progression. Take one LGP from the Pot of Gold if you land on a "take one" square; pay one if you land on a "pay one" square. Landing on unlucky 13s makes you miss a turn.
Troll Bridge and Witch Way: You must spin the exact number to get onto the Troll Bridge, and pay one LGP to the Pot of Gold to advance to the Witch Way. Take your position at the beginning of the path whose colour matches your token. Move ahead according to the numbers you spin, following directions on any space you land on, and spin the exact number to land on the witch at the finish. First to arrive claims any LGPs in the Pot of Gold.
The winner is NOT the person who arrives at the Finish first, but the one who ends up with the most Lucky Gold.
http://allaboutfunandgames.com/wp-content/uploads/2012/10/Hey-Hey-Witch-Way-1969-Game-Board.jpg
May 24, 2011 | Toys
I have installed a supermod on my radio clipped d11 and added varible pwr to the delta tune knob it worked fine for a couple of days the varible was touchy now it will key up but will not modulate. i...
  • Why would you cut d11 when you can adjust VR4 and have it sound so much better? When you cut d11 you put that modulation into overdrive. Put that diode back and adjust VR4 for 100% modulation. That is step one.
  • I assume you added variable power from J36. The problem with adding variable power and not switching the pot is that the wires not only have major loss, running to the pot. And two the stock potentiometer tend to burn up if not replaced with a potentiometer that adjust power by itself. Undo this so called "super mod."
  • Start with a 1969 final for better handling of power.
  • Adjust VR4 for 100% modulation.
  • You can pull the ferrite out of the pot next to the final transistor or you can remove j36 and add a 330uf capacitor (black stripe, negative) to the rear and bias the soldier side with a 33uf resistor. Soldier the resistor to the same soldier points of the Capacitor.
  • Adjust L14,L13 and L12 for power.
Regards, Tony
May 17, 2011 | Cobra 29 LTD CB Radio
Gme electophone tx 4000.is it possible to turn up mic gain on my uhf rig?if so which pot do i turn?thaks in advance ajax66
  • To boost modulation you need to add another diode in series to the diode located next to C92, it will reduce the power a little bit but it does help give the radio more modulation.
  • The AMC itself is the middle pot under the wires towards the front.
  • If you want to do a receive alignment you need a Oscilloscope. Peak on Ch19 T1 - T2 - T2a - T3 - T4 - and do this with a little signal level as possible from the Oscilloscope. Then set the Oscilloscope to -67dB output no modulation and adjust RV1 to not quite light the +30 LED.
You are now set.
One more thing, The finals are a strait drop in. So if one goes just drop in a replacement.
Regards, Tony
Apr 24, 2011 | Radio Communications
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
After a few months, the CD player stopped working. It doesn't spin, and it shows "no" in the clock display
Each CD Player has a potentiometer to adjust the laser assembly alignment. The T609t CD player has a tiny pot of 2000 Ohms (2K) about 1/8 x 1/8 of an inch on a tiny printed circuit board right under the laser assembly. I tried adjusting its value with no success. The wiper was not making contact with the carbon layer below it. I removed it and soldered in 2 wires of 6 inches to work out of the box. I attached at the end of the 2 wires a small printed circuit board of 1/2 x1/2 inch to solder a new pot of 1000 Ohms in series with 50 Ohms resistor. I started increasing the pot value until about 700 Ohms and immediately the Player showed 01 on the display and started to play IL DIVO songs. Obviously after each new setting of the pot I had to repeat the same routine: Power off, power on, hit Play, see No CD message on the display until I found the right initial value on the pot. I still had to tweek it up toward 750 Ohms because it was skipping a bit of song number 8. It is working fine now.
I taped my mod, tucked it in the box and closed the whole thing until the next time it will go out of alignment.
The pot I am using is bigger (3/8x3/8x1/4) it takes 44 turns of 180 deg to sweep it from 0 to 1000 Ohms. The old pot is swept from 0 to 2000 Ohms in one turn of 120 deg. The 50 Ohms resistor was for safety in case I hit 0 Ohms on the pot. I kept it in the mod in case I want to hook a scope.
Cheers
Peter
Jan 18, 2010 | Timex T609T Clock Radio
I know the numbers but I don't know how many times to turn it and in what order
start at 0 counterclockwise pass the first number 3 times and stop on it the fourth. clockwise pass the next number 2 times and stop on the third, counterclockwise pass the final number once and then land on it. Finally turn the dial clockwise until the dial locks into place. In some sentry safes you do the same thing except you need to reverse the rotation.
Oct 01, 2009 | Sentry Fireproof Safe
Temp.
Occasionally with a Bunn you have to add some extra water. Remember when you first got it and you had to add water so that the tank is always full? It may be also that you need to turn down the temp. I need your model number to look for your manual, unless you have your manual? That is where we are going to find the answer. The model number could be on the back but it may also be on the bottom. Let me know.
Aug 25, 2008 | Bunn NHB Coffee Maker
Cobra 29 LTD CB Radio Logo
200 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
