Question about Pride New Jazzy 600 Power Wheelchair by Mobility
Chair wont move
I'm not sure what happened. when i power it up. it just scrolls back and forth. then it turns off. what should i do?
  • 32 Answers
Sounds like problem with joystick, however, you may try checking the cable from rear of the joystick which runs under the seat, make sure its plugged in and not damaged.
Posted on Jul 13, 2009
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
Pride jazzy 1113, controller light scroll back and forth, wont move, i bought one new battery, it has full charge other battery is a little over 10 volts. is there way to test charger with volt meter?
The voltmeter should read 29 volts when on. You should never replace one battery and leave an old battery in the chair. Replace them both at the same time.
Oct 17, 2013 | Pride Jazzy 1113 Power Chair
Can rocking chairs help students with concentration problems?
They sure can! According to research, rocking chairs help students with ADD and ADHD with concentrating better as well as adapting to learning environment. The reason for this is because rocking chairs keep on moving back and forth, the ADD students don't need to worry as much about moving all the time, leaving more room to concentrate on studying.
Oct 24, 2012 | Furniture
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
Nov 30, 2010 | NRS Hoveround MPV 5 - Used Power...
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Lights blinking when power is turned on chair will not move
RB Are the lights giving you a flash code ie: 4 flashes pause four flashes etc or are they all flashing with no pattern? Make sure the chairs freewheel levers are in the drive position then turn it back on to see if they still flash. If the lights are scrolling from right to left then the joystick is in lockout mode. let me know what you find and maybe we can figure this out. Hope this helps you
Sep 11, 2010 | Jet 3 Ultra Power Chair
Pride New Jazzy 600 Power Wheelchair by Mobility Logo
116 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
