Question about DXG Technology DXG-409 Digital Camera
DXG 4.0 MEGAPIXIE DIGITAL CAMERA
WHEN I LOAD THE SD CARD THE CAMERA SAYS MEMORY FULL.IT WON'T DO ANYTHING, BUT YET IT WORKS IN INTERNAL MODE FINE.
    Genius:
  • 2,985 Answers
Is the card Full? Ceck for images and if there are any delete them. If no images - then check yyour manual for the FORMAT mode and format the card - Do Not Attempt to Format in your computer
Posted on May 31, 2007
SOURCE:
I recently bought the vivitar 7024 and bought an sd card lexar multi use 4 gb. For some reason when I take photos and try to look at the pics it says no file exist. But when I take the sd card out and I...
Apparently, you have pics on the camera's internal memory. Your card won't work until those pics are gone. Here's how...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work.
Aug 18, 2011 | Vivitar ViviCam 7024 Digital Camera
Dxg503 in camera mode shows memory full. view mode shows no file. When i try to download to computer it either does not show up or indicates that it is not accessible. using internal memory only
is there anything important in the internal memory? not many pictures can fit there so I suppose probably no?
Format the memory.
Use setup mode to set the camera configurations to suit your personal preferences. Turn the mode dial to SET Mode. And select "Format"
Use the format option to format the camera memory or memory card.
Note: When you format the memory, all data will be deleted.
Now take a few pictures and see if they show up in the view mode or if you are able to get them to the computer. Let me know how that turns out.
Feb 24, 2011 | DXG Technology DXG-503 Digital Camera
The canra says DCF full error agter taking 7 pictuturs
Hi. The PL80 has an 86MB internal memory so it does not sound as if there is anything wrong. However you can buy an SD or SDHC memory card and use that as well, so you can take a lot more pictures.
The number of pictures which can be stored depends on the size of the internal memory, or the extra memory card, and whether you set the camera to record the images in 'Normal', 'fine', or 'super fine' mode. This determines how compressed the images will be, and how much memory each one will use up.
A 1GB card would give around 160 pictures in super fine mode. Have fun with your camera!
Dec 27, 2010 | Samsung PL80 Digital Camera
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
When you insert a new 2gb sd card and the camera message reads card full.
The card may need to be formatted, or it may be that this camera does not support so large a memory card.
Oct 19, 2010 | DXG Technology DXG-305V Digital Camera
Just pt in a neww sd card it keeps telling me that the memory is full and it wont take any pictures
You must have pics on the internal memory. That's what the camera is telling you. You should format the internal memory with no card in the camera. Then, insert the card and it should work properly.
Sep 10, 2010 | DXG Technology Cameras
Move pictures saved in camera to card
Best thing to do is upload them to your computer. The camera does not allow you to move from camera memory to card.
Jan 04, 2009 | DXG Technology DXG-308 Digital Camera
Camera does not read SD Memory Card
thank you so much this worked great it solved my problem thanks.
Oct 31, 2008 | Kodak EasyShare M863 Digital Camera
MY CAMERA WILL NOT TAKE PICTURES, HOWEVER I'M RECEIVING AN MEMORY ERROR MESSAGE
The problem usually relates to using an SD card that is too high in capacity. THE DXG 518 only supports SD cards up to 1 gig in size.
Mar 14, 2008 | DXG Technology DXG-503 Digital Camera
DXG Technology DXG-409 Digital Camera Logo
124 people viewed this question
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
