Question about Mitsubishi WS-65807 65" Rear Projection Television
2 Problems with my Mitsubishi 65" widescreen projection tv
1. I have direct tv and sometimes when the power goes out or something, the picture has shifted to the left. I called Direct TV and they say its the TV. I've fiddled with the remote to no avail. 2. I also have random problems with shadowing. The screen will get progressively dark then lighter though there is always a shadow to the screen. I usually somehow fix it but am not sure how. Thanks for any help!
    Genius:
  • 1,153 Answers
1. THE SYMPTOM IS BRIGHTER IMAGE ON THE SIDES AND DARKER IN THE MIDDLE. THE PROBLEM CAN BE WITH RED BLUE AND/OR GREEN. CHECK FOR PROPER CONNECTIONS TO THE "DAG COATING AND CONNECTIONS TO PIN 9 ON THE SOCKET OF THE AFFECTED CRT. MAKE SURE THESE GROUND POINTS ARE COMMON WITH CHASSIS GROUND
Posted on Aug 21, 2007
Our tv has several white spots blocking out the picture on the tv, what could be the issue?
This problems very exspensive to fix.The Light projection Engine have a problems,with a IC design flaw.This problems happen to many Big screen tvs 65 and up have a design IC flaw by many companies like Sony,Mitsubishi,Toshiba and Samsang.Call up Mitsubishi make some kind of deal with them to help u to fix the Light projection Engine by replacing the IC or replace the whole entire Light projection Egine.
Dec 08, 2010 | Mitsubishi WD-65731 65" HDTV
Mitsubishi WS-65513 65' The red keeps going out
It could be a loose component video cable, check your TV menu or another device when it goes out. If you have red in the menu or other device, it cannot be your CRT. The Crt is somewhat hard to replace but if everything goes great it isn't too bad. I usually mark all the yokes and magnets with a marker so I can put them right back in the same place and the picture should be about the same. Sometimes you need to do a lot of adjustment and that is when it can get tricky, kind of depends on how "identical" the new CRT is to your old one.
Let me know how I can help
Jun 09, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Needing a new remote
if you are wanting the original remote you can visit:
http://www.remotes.com/store/mitsubishi/ws65807.html
if you are wanting to control more than just the tv such as an entertainment center i would go to a technology store such as circuit city and purchase a harmony remote
Feb 16, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Problem with picture
my tv got blue line acroos screen and a yeloow shade on top of screen What can i do
Nov 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-65819 2002 rear projection
1)possible bad RF modulator (the small box the A or B signal first goes thru) 2)Bad tuner (mounted on signal board) 3)or missing voltage to run tuner You could replace signal PCB,but that gets a little pricey.
Oct 03, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
