Question about Blizzard Entertainment WarCraft: Orcs and Humans for DOS
Bad command or file name
I've recently installed orcs and humans to my windows 98 and after I've shut down and restarted the computer I open MSprompt and type WAR, which is what i was instructed said to do at the end of the installation process, the computer responds Bad command or file name. What did I do wrong?
  • linksrival64 Jan 08, 2009
    Nevermind i figured it out. I needed to open the warcraft folder in my computer andclick on war.exe file and sloved my own problem
    Scholar:
  • 97 Answers
You need to navigate to the directory where the game was installed. When you open your DOS prompt you may be in the WINDOWS directory. You should be able to find the application and open it by double-clicking since you're using Windows 98. The instructions you're reading are for DOS.
Posted on Jan 08, 2009
1304 error when trying to install microsoft office student 2007
To resolve this behavior, use the following methods.
Method
: Re-Register the Windows Installer
To re-register the Windows Installer, verify the location of the Msiexec.exe file on your hard disk and in the Windows Registry, and then re-register the Windows Installer. To do so:
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
Verify the location of the Msiexec.exe file on your hard disk. To do so:
Click Start, and then click Search.
Click All files and folders.
In the File name box, type msiexec.exe, and then click Search.
In the search results, make a note of the location of the Msiexec.exe file.
The location of the Msiexec.exe file should be similar to the following example, where Drive is the drive where Windows is installed, and %Windir% is the folder where Windows is installed:
Drive:\%Windir%\System32
An example of this is C:\Windows\System32.
Note In Microsoft Windows 98-based computers, the Msiexec.exe file is located in the Drive:\%Windir%\System folder.
On the File menu, click Close.
Verify the location of the Msiexec.exe file in the Windows Registry. To do so:
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\MSIServer
In the right pane, double-click ImagePath.
In the Edit String dialog box, make sure that the string in the Value data box contains the correct path of the Msiexec.exe file on your hard disk that you determined earlier in step 1.
For example, if the Msiexec.exe file is located in the Drive:\Windows\System32 folder on your hard disk, the correct path of the Msiexec.exe file in the Value data box is the following path, where Drive is the drive where Windows is installed:
Drive:\Windows\System32\Msiexec.exe /V
If the Value data box does not contain the correct path, make the appropriate changes to correct the path, and then click OK.
Quit Registry Editor.
Start your computer in safe mode, and then register the Msiexec.exe file. To do so:
Shut down, and then restart your computer.
Press F8 after you receive the following message:
Please select the operating system to start
On the Windows Advanced Option menu, use the arrow keys to select Safe Mode, and then press ENTER.
If you use a dual-boot or multiple-boot computer, select the appropriate operating system from the list that is displayed, and then press ENTER.
Log on to the computer.
In the Open box, type the following line, and then click OK:
msiexec /regserver
Shut down, and then restart your computer in standard mode.
If the issue persists and you still receive the error message that is described earlier in the "Symptoms" section, follow the steps in Method 2.
Method 2: Reinstall the Windows Installer
To reinstall the Windows Installer, rename the damaged Windows Installer files, and then reinstall the Windows Installer. To do so:
In the Open box, type cmd, and then click OK.
At the command prompt, type the following line, and then press ENTER, where Drive is the drive where Windows is installed and where %Windir% is the folder where Windows is installed:
attrib -r -s -h drive:\%Windir%\system32\dllcache
For example, type
attrib -r -s -h c:\windows\\system32\dllcache
At the command prompt, type exit, and then press ENTER.
Restart your computer.
Update the Windows Installer files on your hard disk to the latest version. __________________
Feb 22, 2010 | Microsoft Office Professional 2007 Full...
Tip
What to do if you want to start a corrupted win 98?
If ur Win 98 system has been corrupted,means only the windows 98 screen appears and then a blue screen appears or after that the system dosnt start or restart follow the following steps:
1. at the time of POST (i.e when u hear the beep sound or when ur monitor shows the first displays) press the F8 key continuously . then select the option Start in Command prompt only
2. in command prompt type C:\>cd windows\sysbckup ( assuming c: is ur system or root directory)
3. then type c:\windows\sysbckup>dir *.cab
4. now select the file depending on the date closest to the date when ur system was operating fine( the file name will be like RB001.cab )
5. now after selecting the file type in the command prompt c:\>windows\sysbckup>copy rb001.cab ..(assuming the file name as rb001.cab)
6. then type c:\windows\sysbckup> cd\
7. then type c:\> extract rb001.cab/e
8.now restart ur pc
happy computing
on Jun 01, 2010 | Computers & Internet
Tip
Common FTP Error Codes
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy - mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; bout to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 File status.
213 File status.
214 Help message. On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1, h2, h3, h4, p1, p2).
230 User logged in, proceed. Logged out is appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information.
421 Service not available, closing control connection. This may be a replay to any commend if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system. File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
on Jan 12, 2010 | Computers & Internet
Message read/ missing export user 32.dll update layerd window.
Greetings,
To resolve this issue, follow these steps:
  1. Restart your computer using the Windows 98 or Windows Me Startup disk.
  2. On the Startup menu, choose the correct CD-ROM support for your computer.
  3. Type the following commands, pressing ENTER after each command:
    c:
    cd <windows>\system
    ren user32.dll user32.dlx
    ren gdi32.dll gdi32.dlx
    ren winmm.dll winmm.dlx
    <ramdrive>\ext.exe
    where <windows> is the name of your Windows folder and <ramdrive> is the virtual drive created by the boot disk (probably e:\ or f:\).
  4. Type the following line, and then press ENTER: For Windows 98:
    <CD-ROM drive>:\win98
    For Windows Me:
    <CD-ROM drive>:\win9xwhere <CD-ROM drive> is the drive letter assigned to your CD-ROM drive. Note that this letter may be different when you boot your computer with the Windows Startup disk.
  5. Type the following line, and then press ENTER:
    user32.dll gdi32.dll winmm.dll
  6. Type the following line, and then press ENTER:
    <drive>:\<windows>\system
    where <drive> is the drive on which Windows is installed, and <windows> is the folder containing Windows.
  7. Review the information displayed. If it is correct, press Y.
  8. Type the following commands, pressing ENTER after each command: cd
    ren Cmapieng.vxd Cmapieng.vxx
  9. Restart your computer.
  10. Once Windows has restarted, run the Defragmentation application.
When Ext.exe has finished extracting the files, follow these steps:
  1. Remove the Windows 98/Me Startup disk, and then restart your computer.
  2. Press and hold down the CTRL key as your computer restarts. On the Windows 98 Startup menu, select Safe Mode.
  3. After Windows starts, on the toolbar click Start, point to Settings, click Control Panel, and then double-click Add/Remove Programs.
  4. On the Install/Uninstall tab, click any utility that you have installed, and then click Add/Remove to remove the utility. Repeat this step to remove any utilities you have installed.
  5. On the toolbar click Start, point to Settings, and then click Taskbar And Start menu.
  6. Click the Start Menu Programs tab, and then click Remove.
  7. Double-click Startup, click the appropriate entry, and then click Remove.
  8. Click Close, click OK, and then restart your computer.
  10. In Microsoft System Information, on the Tools menu, click System File.
  11. Click Settings, on the Advanced tab, click Restore Defaults, and then click OK.
  12. Restart your computer.
Sep 20, 2009 | Microsoft Windows 98 for PC
Windows Installer cannot be accessed. Message shows.I have tried everything but nothing happens.
Method 1: Use the Msconfig tool to confirm that the installer service is running loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the Services tab, click to select the check box that is next to Windows Installer
  4. Click OK, and then click Restart to restart the computer.
If that didn't do it,go to the next step.
Method 2: Re-register Windows Installer
  1. loadTOCNode(2, 'resolution'); Click Start, and in the Search box, type Msiexec.exe,
  2. click Search everywhere for All files and folders.
  3. The location of the file should be C:\Windows\System32
  4. Click Start, and then click Run.
  5. In the Open box, type regedit, and then click OK
  6. Locate and then click the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MSIServer
  7. In the right pane of the Registry Editor window, double-click ImagePath.
  8. In the Edit String dialog box that appears, make sure that the string in the Value data box contains the correct path for the Msiexec.exe file that you determined in step 3.
    If the Value data box does not contain the correct path, make changes to correct the path, and then click OK to close the Edit String dialog box
  9. On the File menu, click Exit to quit Registry Editor.
  10. Start your computer in Safe mode, and then register the Msiexec.exe file.To do this, follow these steps:
    1. Shut down your computer, and then restart your computer.
    2. Restart your computer and press the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, press the F8 key when you see the Boot menu.
    3. Use the ARROW keys to select Safe Mode, and then press ENTER.
    4. If the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
    5. Log on to the computer.
    6. Click Start, click Run, type msiexec /regserver in the Open box, and then click OK.
  11. Shut down your computer, and then restart your computer normally.
Method 4: Reinstall Windows Installer
To reinstall the Windows Installer, follow these steps.
  2. In the Open box, type cmd, and then click OK.
  3. At the command prompt, type the following lines. Press ENTER after you type each line. cd %windir%\system32
    ren msi.dll msi.old
    ren msiexec.exe msiexec.old
    ren msihnd.dll msihnd.old
  4. At the command prompt, type exit, and then press ENTER.
  5. Restart your computer.
  6. Update the Windows Installer files to the latest version
  7. After the installation of the Windows Installer is complete,restart your computer normally
    Check the Windows Installer service (Control Panel - Administrative Tools, Services) is running. It should be set to manual or automatic. Also check the dependency Remote Procedure Call (RPC) service is running.
If that don't do it,Try this Open a command prompt.(Start,all programs,accessories,Right click on command prompt and run as administrator) type sfc /scannow
Feb 22, 2009 | Microsoft Windows Vista Ultimate Edition
Tip
COMMON FTP ERROR CODES
~~~~~~~~~COMMON FTP ERROR CODES~~~~~~~~~~
# Description
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
150 File status okay; about to open data connection.
200 Command okay.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
530 Not logged in.
on Dec 03, 2009 | Computers & Internet
Tip
Cannot Print from Internet Explorer
Issue: Cannot Print from Internet Explorer
Symptoms : When you attempt to print a document or look at it in print preview, you may receive the following error message:
Line: 539
Char: 2
Error: Invalid argument.
Code: 0 URL: res://C:WINDOWSSYSTEMSHDOCLC.DLL/preview.dlg
CAUSE : This issue can occur if the Iepeers.dll file is corrupted or is the incorrect version
Resolution: To resolve this issue, replace the Iepeers.dll file. To do this, follow these steps:
1. Restart the computer in MS-DOS mode or with a startup disk.
a. For Windows 98 and Windows 95 , click Start, click Shut Down, click Restart the computer in MS-DOS mode, and then click Yes.
b. For Windows Millennium Edition (Me), use a Windows Me startup disk and click Start Computer without CD-ROM Support.
For additional information about how to create a Windows Me startup disk, click the article number below to view the article in the Microsoft Knowledge Base:
267287 (http://support.microsoft.com/kb/267287/EN-US/) How to Create a Startup Disk in Windows Me
2. Type the following commands, pressing ENTER after each command:
c:
cdwindowssystem
ren IEPEERS.dll IEPEERS.old
exit
3. Extract a new copy of the Iepeers.dll file to the WindowsSystem folder. You can extract the Iepeers.dll file from the following location:
The IE_5.cab cabinet file included with Internet Explorer 5.5 for Windows 98.
4. Register the Iepeers.dll file. To do this, click Start, point to Run, and then type the following line:
regsvr32 IEPEERS.DLL
5. Click OK.
6. Restart your computer normally.
on May 30, 2008 | Microsoft Windows Vista Home Premium with...
Sony vaio not loading windos
Try booting XP with the installation CD & use the recovery console to boot the laptop.
From the Setup CD-ROM
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
To exit the Recovery Console and restart the computer, type exit.
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Windowslive messenger not responding keeps coming up error8100030d
Error: 8100030d If you are receving the error code 8100030d when signing into Messenger, do the following: 1. Determine what version of Messenger is installed on the computer, and then upgrade Messenger if it is required: 1.a. Click here to determine the most recent versions of Messenger for each operating system. If you are not running the latest version for your operating system, please install the most updated version. 2. Delete the cache files for Messenger. Follow the steps below based on which version of Messenger you are using: 2.a. For MSN Messenger: 2.a.i. If you are running Windows XP or Windows 2000 click Start, click Run, type cmd , and then click OK to open the command window. 2.a.ii. If you are running Windows 98 or Windows ME, click Start, click Run, type command , and then click OK. 2.a.iii. At the command prompt, type the following commands. After each command line, press ENTER:
cd\
cd %appdata%\microsoft
cd "msn messenger"
del /s listcache.dat 2.b. For Windows Live Messenger: 2.b.i. For Windows XP
  • Right click on the Start button and then click Explore to open Windows Explorer. On the Tools menu, click Folder Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Click to clear the Hide extensions for known file types check box . Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them
C:\Documents and Settings\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts\ Your Messenger email address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
2.b.ii. For Windows Vista
  • Click Start and then click Explore to open Windows Explorer. On the Organize menu, click Folder and Search Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Clear the Hide extensions for known file types check box. Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them.
C:\Users\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Users\ Your Windows logon name \AppData\Local\Microsoft\Windows Live Contacts\ Your Messenger e-mail address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
3. Try to sign in to Messenger again.
Aug 24, 2008 | Computers & Internet
How do I re-format a 2x serial SATA drive to reinstall XP?
How to Format a Hard Disk
After you create the partitions, you must format the partitions:
Restart your computer with the Startup disk in the floppy disk drive.
NOTE: If you are using a Windows 95 Startup disk, a command prompt is displayed and you can skip to step 2. If you are using a Windows 98, Windows 98 Second Edition, or Windows Me Startup disk, select the Start computer without CD-ROM support menu option when the Windows 98 Startup menu is displayed.
2. When a command prompt is displayed, type format c: /s and then press ENTER. This command transfers the system files and should only be used when you format drive C (or your "active" drive). For all other partitions, type format drive: (where drive is the letter of the partition that you want to format).
NOTE: If you receive a "Bad command" or "Bad file name" error message, you may need to extract the Format.com tool to your boot disk. To do this, type the following command at a command prompt, and then press ENTER:
Extract ebd.cab format.com
After the Format.com tool is extracted to your boot disk, type format c: /s t a command prompt to format your active partition, or type format drive: if you want to format a partition that is not your active partition.
3. When you successfully run the Format.com tool, you receive the following message:
WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
Proceed with Format?
4. Press Y, and then press ENTER to format drive C.
5. After the format procedure is finished, you receive the following message:
Volume label (11 characters, ENTER for none)?
NOTE: This is an optional feature that you can use to type a name for the drive. You can either type an 11-character name for the drive, or you can leave it blank by pressing ENTER.
Jul 25, 2008 | Computers & Internet
Blizzard Entertainment WarCraft: Orcs and Humans for DOS Logo
106 people viewed this question
Top Blizzard Entertainment Video Game Consoles & Games Experts
James Wishart
EnergeeUK
Level 1 Expert
Josh Hannegan
Josh Hannegan
Level 1 Expert
Are you a Blizzard Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
