Glass inside door panel cannot grab it, will not roll up, need to know where to start to repair it
SOURCE: Radio Code for 1999 Mercedes E430
If you call your merc dealer they should give it to you on the phone, if not have a look at this web site, if not, then if you take out the unit and let me know the s/no: i will see i have it.
http://www.radio-code.co.uk/code-entry-help.php
[email protected]
SOURCE: 1999 Mercedes E430. Sometimes it will start,
Changed the crank sensor. Thanks for the help I didn't get.
SOURCE: 99 e430 right rear window still doesn't work after replacing regulator and motor
could be the window switch or the fuse is blown or the wires r shorted to the window motor. did u check for power and ground at the motor before u replaced it?
