Question about GE GSS20IEP Side by Side Refrigerator
Ge gss25jema ww side by side freezer fan runs almost constantly
The fan stops when the fridge or freezer door is opened. Bottom of icemaker seems to have a little frost build up as well as some food near the top of the freezer. Any ideas?
  • 3 Answers
SOURCE: Ge Fridge freezing in fridge area
The freezer should be set to 0 degrees and the fridge 37 degrees according to the manual. If your unit has only numbers then it would number 4 or 5 for the freezer and 6 or 7 for the fridge.
Posted on Jun 23, 2008
  • 1462 Answers
SOURCE: ge fridge gss20ieph ww
ac volts
Posted on Jul 11, 2008
eagle338
  • 4889 Answers
SOURCE: frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Posted on Sep 02, 2008
  • 310 Answers
SOURCE: GE fridge: Freezer working but fresh food side not cold
The problem is the refrigeration evaporator, located in the freezer section is blocked with frost and ice and not air can pass through it. Four different failed parts can cause this problem. The defrost timer, the defrost heater safety thermostat, the defrost heater, or the evaporator fan motor. Unless you are very good with a volt-ohm meter, it wiil be difficult to distinguish which one of these parts has failed. A qualifed refrigeration service tech or a good appliance service tech with a refrigeration certification can find this quickly.
Posted on Jan 13, 2009
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
Hot point Manufactured by GE MD# HSS25GFPE WW Not Cooling Fridge or Freezer.
Is compressor (black canister)running? It should be very warm if it is. If not, motherboard is most likely bad.
Oct 20, 2017 | Hotpoint HSS25GFP Side by Side...
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
163 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
