Question about PC Chips G320 Notebook
Evesham / ecs g320 notebook, screen wont come on but powers up.
I first had a problem with the dvd-rw , it wasnt bein recognised in the bios. thought there was a loose connection but there wasnt. opened case and checked. now the screen wont come, but it powers up. checked for a loose connection with the screen and there isnt. when speakers are connected there is no sound to what i can hear. i have tried to connect a external monitor and key but no joy. the bios battery is connected via a small black and red cable which i took out and slotted back in to reset the bios to see if it had any effect with the dvd drive not being detected. i would very much like assitance please with the problem
  • Curtis Tuendemann May 11, 2010
    Ok so where is the issue lying at the moment? it sounds like you have had alot of issues.
  • Logan Kinnaird May 11, 2010
    a what
I have a G320 laptop with 512 SO-DIMM DDR400 and 1 GhZ procesor ,OS WIN XP, how can I run my G320 faster
There is nothing much that can be done to speed up the system as it can not go beyond 1GHz Processing speed, but several operating system tweaks and some hardware upgrade could make a little but notable difference.
As for Hardware, you may increase the RAM. You can upgrade memory on ECS Elitegroup Computer G320 upto a maximum of 1.0 GB (The ECS Elitegroup Computer G320 takes the PC2100 DDR SDRAM SODIMMs Memory)
Secondly, You may increase the size of PAGE FILE, uninstall unwanted software, Remove unwanted start-up items, Clean Junk Files/ Temporary files, De-fragment the Hard Disk to achieve the maximum speed and performance that EliteGroup G320 PC can give.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | EliteGroup G320 Notebook
The ie wont respond
Try to restart your computer. If ie wont respond its usually because it crashes. Best browser firefox.
Jan 25, 2010 | EliteGroup ECS 600 BAREBONE NOTEBOOK...
How enter ECS elitegroup G320 laptop bios
I have ECS A900 and to enter BIOS, you press DEL key.
I found that the hard way :)
Oct 31, 2009 | EliteGroup G320 Notebook
Elitegroup/ECS Laptop G320 - it's dead mom :-(
It's because of faulty capacitors. Look here:
http://www.fixya.com/support/t890498-laptop_power_elitegroup_g320_pc_notebook
Oct 07, 2009 | EliteGroup G320 Notebook
Dvd-rw recognises dvd's but wont recognise any cd
hey alan,
u can go here for the latest drivers of your notebook
http://support.acer-euro.com/drivers/ftp/ftp.html
than click on : notebook
than click on : aspire 1640
than click on: any map u whant for updates
Jan 01, 2009 | Computers & Internet
Toshiba Satellite Pro L20 fitting DVD Writer
Try to find the correct driver from Toshiba for the driver, your current one wont work for the dvd.
Mar 27, 2008 | Computers & Internet
DVD-RW optical drive
is your dvd detected in bios ?
if yes, it's windows issue.
follow the step by step from this link:
http://support.microsoft.com/kb/314060
Feb 29, 2008 | Acer Aspire 3003WLCi Notebook
3 long beeps of my elitegroup ecs green 320
If you cangatehr this much of information you are no less than a computer engineer. Nobody needs to build a car to change its tyre. If you arrange a spare HDD and RAM, remove the original HDD and try to install windows on that. And if problem persists do the same with RAM also. I am sure you could solve this problem yourslef.
Oct 06, 2007 | EliteGroup ECS G900 Notebook
3 long beeps with my Elitegroup ECS Green 320 laptop
Let's start with the most overlooked reason. Sounds like the battery died. Is your laptop's battery fully charged. Plug it in over night and give it a good chance to recharge the battery. Then turn on your laptop WITH the power cable attached. Did this solve your problem? If not we'll go to the next step.
PC Chips G320 Notebook Logo
3,378 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
