Question about E-Machines T2042 CELERON 2 GHz 128 MB 40 GB HDD Dsktop Computer System PC Desktop
Desktop Lockup Hello. I have an emachines model T2042 desktop and it has started to lock up and the activity light below the power button blinks at a steady interval, and I can hear a rhythmic "knocking" inside the machine. I have to unplug the power cord from the rear of the machine to get it to power cycle, and then turn it on again. It's a Celeron, 2GHZ machine, with 128MB of original memory. Could this be a power supply issue? I know it's an old machine, but was planning on giving to my sister, but if it's on it's last legs, then ......
  • dirtbag170 Jan 08, 2009
    Ok, thx for the answer. Much appreciated.
    Novelist:
  • 180 Answers
Remove the cover to look at the power supply fan while it is powered on ( if needed). The fan should be spinning at a steady rate. If you observe fluctuations in the rotation, these are early indications of a malfunctioning power supply unit. As for the knocking sound, can you hear it better or determine its source if the cover is removed? It could be the fan hitting the side of the power supply or wiring. The good news is that if it IS the power supply, they are relatively inexpensive and easy to replace. Your sister may not be out of luck!
But if the light is blinking- and orange - this is definite indicator that the power supply is going. Still a good idea to replace the p/s unit and let her use it. With RAM being as cheap as it is, I'd also recommend bumping it up to 512 minimum if not a 1 GB.
Posted on Jan 08, 2009
Emachine w3611 power button blinks but won't start computer
Try unplugging from power source and leaving for about three minutes and then plug it back in.
May 12, 2015 | eMachines W3611 PC Desktop
In sleep mode power light blinks can i stop this?
Put a piece of tape over it
Regards,
joecoolvette
Mar 30, 2013 | E-Machines eMachines Desktop PC
Emachines t2042
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Jun 07, 2012 | E-Machines eMachines Desktop PC
T2042 emachines audio problems
It's easy to fix this problem.
Stop using the audio chipset on the motherboard, and install a Sound Card.
They are economical, and will surpass the audio quality of that eMachines motherboard, by a mile.
The eMachines T2042 Desktop PC, uses one of these TriGem Imperial motherboards,
http://www.e4allupgraders.info/dir1/motherboards/socket478/imperial.shtml
Scrolling down you can see the audio is AC'97.
Not worth writing home to Mom about.
The Sound Card you obtain will go into one of those long white PCI slots.
(There are 3)
Any available PCI slot that is open, with no adapter card in it.
Here is but one example of a sound card that will work,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=420797&CatId=2771
Need guidance in installing? Post in a Comment.
[ Remember to follow Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out, (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE working on your computer.
Computer on a table, computer Unplugged from power, computer case open.
TOUCH an unpainted surface of the metal frame, of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be
SURE to Touch the metal frame again upon your return ]
May 20, 2012 | E-Machines T2042 PC Desktop
It makes noise then the tower cuts off but the power still blinks alot..the model number is T6532...it has been this way for a week. It just shuts everything down. The yellow light blinks alot.
Hello
Possible bad power supply,or step down transformer.If the noise your talking about is a beep or a series of beeps then this is called a beep code or codes.
Refer to the manufacturer for reasons for beeps.
Mar 10, 2011 | E-Machines eMachines Desktop PC
Nothing on the monitor, the computer powers up and e machine f2 comes up on the screen then goes blank
hello bradprice258
I am assuming you have an LCD monitor
when the computer turns on look carefully at the front face of you computer case, there are two small LED lights. one is power and one is hard disk activity.
look at the one for hard disk activity. watch it for a few mintues, if it is activly blinking and then turns off or becomes a random blink then it means the possibility is a faulty monitor. LCD monitors do that once they age or get hit by power surges or black outs.
if both lights in front of the case go out as you loose display then the problem is with Po itself. could be bad power supply of main board.
hope this has been of help.
please do leave comment if this has helped.
Feb 10, 2011 | E-Machines eMachines Desktop PC
What is the best replacement for my T2042 computer.
It all depends on what you are looking for. If you are looking for a Gaming desktop then I'd recommend Alienware If your looking for producing and editing videos I'd recommend an HP or Sony possibly Mac. For an all around PC go for a Gateway, Acer, eMachine or any other lower branded computer.
Apr 26, 2010 | E-Machines T2042 PC Desktop
I have a 3507 emanchines computer.When I push start button all it does is show green light clicking . Then it will stop and the white light will below will blink 7-8 times. The green light will click about...
sounds like an issue with your motherboard or something like that...try resetting the motherboard by unplugging the power, taking out the battery of the motherboard inside the computer and pressing the power button several times to drain the power. then put the battery back in, plug in the power cord and try to start it up. if it doesnt work then ur gonna have to contact emachines because ur mobo is either defective or broken...
Nov 12, 2009 | eMachines W3507 PC Desktop
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
EMachines T5026 won't start. Start button blinks when I hold it in. The machine clicks and fans run, but the machine will not "turn over".
Hello!
Your manual can be found on the Logitech website found here:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=2DzbXkLj&p_li=&p_accessibility=&p_redirect=&p_tbl=9&p_id=6429&p_created=1174511175&p_olh=0
Oct 26, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
67 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
