Question about RCA F20625 20" TV
Hooking up & seeing a dvd player?
I don't have the original remote control for the RCA F20625, but I want to hook up a dvd player to it. It has the yellow/white/red video & audio connections, so I figure it should work, right? Only thing is, when you go through setup it only asks if you have a VCR...no selection for DVD. Is it impossible to play a dvd on this thing? Is there some special code I have to enter? Is there some way to switch the input like AV1, AV2 or whatever without the original remote? The DVD player I am trying to use is a Samsung (model: DVD-HD841/XAA). Help!
  • 905 Answers
Does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Posted on Jan 08, 2009
Memorex mt2024 bought used w/o remote. Need to reset back to original settings. There is a parental control on a couple of channels and I don't know the password. Here's the BIG ISSUE, though: ...
To unlock all its locked functions, you must have its original remote control A universal remote control won't go. Try to get its original one. Don't waste more money by buying a universal remote control.
Jul 14, 2013 | Televison & Video
Codes for bp59-00016 samsung remote to hook up a rca dvd player
Try the code 002 for an RCA DVD player for the BP59-00016 remote. This is the only code given for RCA DVD players for several Samsung TV universal remotes (BP59-0007 and the BP59-00016A). A manual for a TV with the BP59-00016A remote is here: http://downloadcenter.samsung.com/content/UM/200303/20030325191047000_L62A_ENG_1210.pdf .
You may need to check the age of the remote. The codes in a universal remote generally only control those devices released 6 months or more before the remote was programmed. If your RCA DVD player is newer than your remote, you may need a new remote.
I hope this helps.
Oct 12, 2011 | Samsung BP59-00016A Remote Control
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
My DVD player is hooked up to my RCA truflat but i cannot find the picture. I lost the original remote to my RCA truflat and am now using a RCA universal remote. How do I get picture on my tv?
There should be a button on the front of the TV that says TV/VIDEO or INPUT. Turn on the DVD player and put a DVD in it and press play. Press the TV/VIDEO button until the picture is present.
Good Luck....
Jan 19, 2010 | RCA 14F512T 14" TV
How do I hook up a DVD player without a remote?
You can buy a universal remote philips are rca and that would work with your dvd player rca mot rcu404
are philips sru3003wm/17
Dec 09, 2009 | Emerson EWF2703 27" TV
Trying to get my TV can't find manuel or remote
Press the "Input" or "Source" button on the television while you have the DVD player on. Press it repeadly until you see the DVD picture on the screen.
Basically, just try changing the input on the TV to the input that the DVD player is hooked to.
If this doesn't work, you may have to get the original remote, or get a universal remote to control some of the television's features.
I hope this helps :)
Best Regards,
James
Jul 21, 2009 | Televison & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Hooking up a DVD Player with NO remote
Some TV's will let you access inputs by going through the channels to the very end and see if it works.
Jul 29, 2007 | RCA F25674GY 25" TV
RCA F20625 20" TV Logo
214 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
