Question about Dell DJ Ditty MP3 Player
Corrupteed and Unrecognized Device
When I place the USB drive in my computer I can't open the drive. A windows prompt message is displayed "Unrecognized and corrupted device" I can't even format the drive in DOS.
  • Anonymous Nov 18, 2007
  • 883 Answers
If this is your first attempt ever at this particular MP3 and pc link, is it possible the dell device is a USB 2.0 required port while your pc is limited to USB 1.0?
Posted on May 31, 2007
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
Tip
How to Download Files to USB Flash Drive
MS Windows Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. <br />Depending on your computer, there can be USB ports on the back, side or front. The flash drive can also be connected to an external port hub device. Once you connect it, the computer will automatically recognize it as a removal device.<br /> 2.Double-click "My Computer" on the desktop. You should see your USB flash drive's icon listed together with other removal devices on your computer.<br /> 3.Double-click the flash drive's icon to open the flash drive window and <br />reveal the contents saved on it. Locate the file you want to download to the <br />flash drive from its current location on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive.<br /> 5.Close the flash drive when you are done. Click the "Safely Remove Hardware" icon on the system tray. A new window will open. Left-click the flash drive and click "Stop." A message will pop-up indicating that it is safe to remove the device from the computer. Disconnect the USB flash drive from the computer (or external hub).<br /> <br />Mac Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. The computer will automatically recognize the device and display its icon on the desktop.<br /> 2.Double-click the flash drive icon on the desktop to open its window and <br />reveal the contents on it.<br /> 3.Locate the file you want to download to the flash drive from the location <br />where you have it saved on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive. Close the flash drive window when you are done and drag the flash drive icon to the trash can to safely eject it from the computer.
on Feb 01, 2011 | Computers & Internet
Recover lost and hidden files on usb stick
If your files are hidden due to a viral infection, you can unhide them by going to "Computer" and seeing what drive letter your USB device is connected to. Next open a command prompt [hold down the "windows" key then press 'R'] On the 'RUN' window that appears, type 'cmd'
When the command prompt opens, type the drive letter of your USB drive, i.e H:, J:, G: etc...the command prompt should change to that drive letter. next type
attrib -s -h /s /d
the above command will unhide any files and folders that have been hidden on your drive
Nov 07, 2013 | Computers & Internet
Maxdata pro 5000 ir
There are many good reasons for booting your computer from a USB drive.
For instance, if you want to try out another operating system without disturbing the main hard drive on your computer, then installing the new OS on an external drive is a great way to run the system through its paces and decide whether you like it.
This approach will offer you the flexibility of being able to run both operating systems on your computer.
However, before you can boot the new operating system from the USB drive, you will need to change the boot order for your computer in the system BIOS.
Connect the external USB drive or pen drive to the computer before you power it on.
Press the "Delete" key as the computer performs the "Power On Self Test" (POST) to enter the BIOS area of the computer firmware.
The POST performs a diagnostic of components on the motherboard and does a cursory check of the hard drive, memory and processor.
The POST only lasts a few seconds; therefore, press the "Delete" key quickly.
Enter the administrative BIOS password if prompted to do so.
Once you enter the correct password, you will see the main BIOS screen.
Use the right-arrow key to navigate to the "BOOT" menu option at the top of the screen, and press the "Enter" key.
Press the down-arrow key until the cursor is on the "Boot Device Priority" label. Hit "Enter," and press the down-arrow key again to highlight the "1st Boot Device" option.
Press the "+" or "-" keys to scroll through the available boot options until the "USB Drive" or "USB-HDD0" label is the highlighted option.
Press the "F10" key to save changes and exit the BIOS setup program.
When the computer restarts, wait for the "press any key to boot from external drive" prompt to display, and then press any key on the keyboard to boot from the USB drive.
Award or Phoenix BIOS
Connect the USB drive to the computer.
Wait for the POST to display on the screen, and press the "Delete" key to enter the BIOS.
Enter the BIOS password if prompted to do so.
Tap the right-arrow key until the cursor is over the "BOOT" menu option.
Press the "Enter" key.
Press the down-arrow key until the highlighted cursor is on the "Removable Devices" option. Press the "+" key until the "Removable Devices" label is on the top of the boot device list.
Press the "F10" key to save the changes for the boot order in the BIOS and to exit the utility.
After the computer restarts, press any key on the keyboard to boot from the USB drive when prompted to do so.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
Jun 22, 2013 | Computers & Internet
Device cannot start code 10 message
If your system is displaying code 10 or "the device cannot start" error messages, resolve the problem with a little troubleshooting.
These messages arise when your computer does not recognize universal serial bus (USB) devices.
Faulty USB devices or malfunctioning drivers are common causes of a unrecognized USB device. It is important to detect and repair the underlying issue to prevent serious harm to your personal computer.
Plug the USB device into another computer.
If the alternate computer displays the code 10 error, there is a problem with the USB device.
Return the device or purchase another one.
Plug the new device into your system. Make sure the code 10 error does not appear.
Click "Start" and right-click "Computer."
Select "Manage" and click "Continue" if the "User Account Control Prompt" appears. Open "Device Manager."
Select the faulty USB device.
Notice a yellow exclamation warning next to it.
Right-click the faulty USB device driver and select "Update Driver Software."
Allow the driver to update.
Right-click the faulty USB device driver and click "Uninstall."
Exit the Device Manager.
Restart the computer.
Allow Windows to reinstall the driver automatically.
Ensure that the USB device is working correctly.
If you computer came with a motherboard disk the drivers should be on it.
or
Rather doing a driver hunt which can take hours
http://ct.download.com/clicks?t=1169844150-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
May 05, 2013 | Dell Dimension E520 PC Desktop
How to boot from usb flash drive
There are many good reasons for booting your computer from a USB drive. For instance, if you want to try out another operating system without disturbing the main hard drive on your computer, then installing the new OS on an external drive is a great way to run the system through its paces and decide whether you like it.
This approach will offer you the flexibility of being able to run both operating systems on your computer. However, before you can boot the new operating system from the USB drive, you will need to change the boot order for your computer in the system BIOS.
Connect the external USB drive or pen drive to the computer before you power it on. Press the "Delete" key as the computer performs the "Power On Self Test" (POST) to enter the BIOS area of the computer firmware. The POST performs a diagnostic of components on the motherboard and does a cursory check of the hard drive, memory and processor. The POST only lasts a few seconds; therefore, press the "Delete" key quickly. Enter the administrative BIOS password if prompted to do so. Once you enter the correct password, you will see the main BIOS screen. Use the right-arrow key to navigate to the "BOOT" menu option at the top of the screen, and press the "Enter" key. Press the down-arrow key until the cursor is on the "Boot Device Priority" label. Hit "Enter," and press the down-arrow key again to highlight the "1st Boot Device" option. Press the "+" or "-" keys to scroll through the available boot options until the "USB Drive" or "USB-HDD0" label is the highlighted option. Press the "F10" key to save changes and exit the BIOS setup program. When the computer restarts, wait for the "press any key to boot from external drive" prompt to display, and then press any key on the keyboard to boot from the USB drive. Award or Phoenix BIOS Connect the USB drive to the computer. Wait for the POST to display on the screen, and press the "Delete" key to enter the BIOS. Enter the BIOS password if prompted to do so. Tap the right-arrow key until the cursor is over the "BOOT" menu option. Press the "Enter" key. Press the down-arrow key until the highlighted cursor is on the "Removable Devices" option. Press the "+" key until the "Removable Devices" label is on the top of the boot device list. Press the "F10" key to save the changes for the boot order in the BIOS and to exit the utility. After the computer restarts, press any key on the keyboard to boot from the USB drive when prompted to do so.
also
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/ boot from a usb drive
Apr 16, 2013 | HP s3700y PC Desktop
4 gb pendrive led glows but now shown in my computer, i tried to check in many computers and laptops but the same problem. please help me.
umm, how old are your computer and laptops that you're using to check?
It could be that they don't have a USB 2.0 port.
Is there any message at the bottom right of your computer when you plug it in saying anything related to a USB device.
Also you can click on Start/"right-click" My Computer/Manage/Device Manager/Universal Serial Bus Controllers --- make sure that this says it's working properly and enabled.
Dec 09, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Un recognized drive
what you should do is search for a driver for it so put the name of the usb then driver in a search engine and download and install a driver this should make the computer able to recognise the usb's software
Apr 04, 2009 | Western Digital WD Passport 250GB Portable...
Maxtor 3200 error code 10
To uninstall a device
  1. Open Device Manager.
  2. Double-click the type of device that you want to uninstall.
  3. Right-click the specific device you want, and then click Uninstall. You can also double-click the device, and then on the Driver tab, click Uninstall.
  4. In the Confirm Device Removal page, select Delete the driver software for this device if you also want to remove the device driver package from the driver store. .
    The Delete the driver software for this device option removes the package from the driver store. It does not remove the currently installed driver for any other operational devices that use the same driver. If you remove the driver from the store, and the device is connected to the computer again, Windows must search for a copy of the driver package in the standard search locations, including possibly prompting the user for media. This option is the equivalent of running the command: pnputil -d -f <package.inf>. For more information, see Remove a Driver Package from the Driver Store.
  5. Click OK to complete the uninstall process.
  6. When the uninstall process is complete, unplug the device from the computer.
    If you are prompted to restart the computer, the removal is not completed and the device might continue to function until the computer is restarted.
Reinstall a Plug and Play device Reinstall a device only if it is working improperly or it has stopped working altogether. Before you reinstall a device, try to restart your computer and check the device to determine whether it is functioning properly. If it is not, try reinstalling the device.
To reinstall a Plug and Play device
  2. Follow the instructions in the preceding procedure to uninstall the device.
  3. If you are prompted to restart the computer, follow these steps:
    • Plug in the device and then restart the computer. The device will be detected and reinstalled after Windows restarts.
    • Follow any instructions on-screen to complete installation.
  4. If you are not prompted to restart the computer, follow these steps:
    • In Device Manager, in the Action menu, click Scan for hardware changes.
    • Follow the instructions on the screen.
Dec 05, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Tripp-Lite USB to serial
Windows XP has gone long ago obsolete.
Suggest upgrade with a new computer to Windows 10.
Mar 02, 2018 | Tripp Lite Computers & Internet
Dell DJ Ditty MP3 Player Logo
110 people viewed this question
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
