Question about Nintendo The Legend of Zelda: Phantom Hourglass for DS
Drawing the tri-force
I've tried several times to draw the tri-force to open the door and it won't let me finish before it says nothing is happening! Ugh, very frustrating!!
  • 3 more comments
  • ccarrier Jan 08, 2009
    Hi ddogg871, I've tried what you said hitting Ctrl + F then typing Drawing and I'm getting nothing. I have tried for over 1/2 hour now drawing the two triangles and getting nowhere. Maybe I'll try it at home on my internet see if I get anywhere...
    Thank you. I googled the drawing and found it. I've tried it several times the way the diagram is telling me and it hasn't worked. it stops me after I've finished the small triangle and won't let me continue on to finish the large one!
    Thank you for you all your help!!
    HALLELULIA!! It FINALLY took it! Had to hold my tongue the right way I guess... Thank you again!
  • heiditoscot Jan 17, 2009
    hi i cant finish drawing the tri-force please help
  • Anonymous May 21, 2009
    I have tried hundred times drawing the triforce in one go but it never works im getting really annoyed i need help
  • 132 Answers
You have to draw the triforce in one continuous line.
hit Crtl + F then type Drawing and its near the bottom a pic that shows you step by step how to draw the triforce in one continous line.
Posted on Jan 08, 2009
  • Derek Powers
    Derek Powers Jan 08, 2009
    try searching for drawing lol. hang on here:
  • Derek Powers
    No problem man, glad to help!
Why does the image start several inches down the page from where it should.
check the media selection using metric like A4 and A3 paper or using 81/2 x 11 media check the paper draw settings and the print driver selection and printer properties. whipping lens does nothing does this happen when using a different draw or the bypass tray?
May 03, 2014 | Konica Minolta magicolor 2500W Laser...
The draw won't open
Try Plugging it in, Ensuring you have power, Tap the Top and Bottom. IT probably means your DVD is jammed in there.
If this does not work, UNPLUG it and take the cover off and manually open the Door...
Apr 07, 2013 | Computers & Internet
2000 Chevy S10 passeger door won't open
Remove the door panel and inspect the latch rods for damage or broken retention clips. A video is below of how to remove the panel.
Nov 06, 2012 | 2000 Chevrolet S-10
Just finished driving car, tried to start it back up and nothing happens. Radio works fine, lights come up but car won't start.
if starter is not engaging or clicks then have battery load tested. if battery checks good then test the voltage draw on the starter,may be dragging when it gets hot.
Jun 03, 2012 | 2002 Kia Spectra
I have a Automatic Doorman Model 455, problem is door goes down with no trouble, but lifting it goes about 10" and stops. I have changed the "V" belt, the problem still exists. I did an...
You are probably right about the motor going.Does it get to a point where the door stops and the motor is making a humming sound? If so the motor is going for sure...In the mean time to get you by,try putting more tension on the spring of your door to give the electric door opener a little extra help as its opening.
Nov 15, 2010 | liftmaster Chamberlain Garage Door Opener...
Ds hannah montanawhen I draw the shape to open the door the shape
u hav 2 make sure ur drawing the shape correctly keep trying till u get it right
Jul 26, 2010 | Disney Interactive Hannah Montana for DS
Rear door dosn't lock
the problem is the lock actuator . it needs to be replaced and its no easy job
Apr 18, 2009 | 2006 Ford Focus
Over night the battery is dead
Put a 12v test light between the positive terminal and the battery cable.If the light is bright the draw is to much.A dim light is fine.if the light is bright,plug one fuse at a time until light dims.DO NOT cause a draw by leaving a door open etc while testing.DO NOT try and start the car or turn the key on during this test.Once you have found the fuse that causes the most draw,if you want to save $ you can just pull this fuse overnight or wire that circuit with a relay to unpower it when the vehicle is switched off.
Apr 28, 2017 | 2004 Dodge Neon
Dishwasher Draw will not open after Washing
Turn off at wall, DW resets, and you can open drawer. Tell wife not to stuff so much in next time.
Apr 11, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Nintendo The Legend of Zelda: Phantom Hourglass for DS Logo
702 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
