SOURCE: sky not working properly on my samsung lcd tv
This is likely to be caused by the changing of the screen mode between ads and or programs, by your TV.
If so, changing the Sky output to 16:9 will fix it.
Press [Services]
Select option 4 - System Setup
Select option 1 - Picture Settings
Change "Location 1" TV setting to 16:9 (This will make the Sky box handle any changes and give you a permanent widescreen output to your TV. This is the recommended setting for widescreen TVs, but sadly, few Sky installers bother to do it.
You can also change "Location 2" if you have a second widescreen TV connected in another room.
Whilst in this menu change the Video Output to RGB from PAL (If not set already) RGB gives a much more stable picture (particularly on the menu system)
Go to Save new settings and press [Select]
Exit the menu system, and you problem should be solved.
SOURCE: Plasma Tv 42PD580DTA, Black and white screen while viewing DVDs or Video
My sister-in-law has exactly the same problem and is a common one with this unit.
I've spoken to a technician who says that:
1. Hitachi are withdrawing from Australia and there are VERY limited service centres left
2. The problem is a chip on the main board and depending when the TV was made will determine whether the chip is a plu-in or soldered on to the main board - if it's the latter, you'll be up for a main board at around $400
3. He couldn't get the price of the plug-in chip because he couldn't get through to Hitachi.
Cheers
Dave M.
SOURCE: I lost the remote for
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: dynex tv no picture screen comes on and then goes black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: TV loses picture about 2 seconds after turning on
sounds like a bad capacitor in the power supply
