Question about Xerox CopyCentre C118 Copier
Replace tonner catridge error
Even after filling up the catridge with new tonner it is showing the same error. The machine is presently on an Oil Rig and we are sailing from Singapore to Capetown. Kindly give all your technical know-how so that we can continue using the copier at the earliest and get a service personel to attend to it as soon as we reach the next Port of call.
    President:
  • Xerox Master
  • 990 Answers
Dear Sir; You fill up the cartridge that's fine,but you forget to change RF chip, it located right behind the cartridge, if you don't replace it , machine not going reset .
Posted on Jan 10, 2009
Sir, estudio212 photocopy machine showing tonner not reconised error. I already tonner replaced
Be sure that the part numbers are exact, if still doing the same thing return and replace.
Oct 18, 2013 | Toshiba Office Equipment & Supplies
Hi Sir. I got a problem of my Toshiba e studio 3510c printer, when I swich on the button, the screen shows there is a sentence said ;'disposal of the used tonner', should I replace the wasted...
It said exactly what? If it mentioned waste toner, emptying that tray (Toshiba has nice zero-waste-to-landfill toner recycling program) should have pretty much cleared things up; it appears that the sensor for that still sees lumps of toner..or something...coming up close to the paper path. Check it out carefully and replace the tray.
Sep 10, 2011 | Office Equipment & Supplies
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
How do i fill tonner cartrage
you might as well just get a new toner catridge
May 16, 2010 | Samsung CLP670ND Colour Laser Duplex...
I have a problem in my hp4700 printer.everyday morning i need to shake the tonner for getting good quality print.Iam using hp genuine tonner catridges.I changed all toners with new HP genuine.still printer...
Normally that works when toner is real low. But if you are doing that with good toner levels then it may be humidity in the room making the toner powder clump or stick.
Have you performed a clean cycle/test. You may have problems with a fuse roller but that would be a longshot thing to check for.
Mar 23, 2010 | HP LaserJet 4700 Printer
Printer problem
how to shot the printer chip of scx4300 for refresh the tonner for printing
Feb 18, 2010 | Samsung SCX-4300 Monochrome Laser...
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Dear Sir; I don't know what kind error message you have, if only request replace toner cartridge, go buy one replace it.
Jan 08, 2009 | Xerox CopyCentre C118 Copier
BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Xerox CopyCentre C118 Copier Logo
100 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
