Hi I have a washing clothes machine LG one and i it is working normaly when it come to the dryier stage while there is too much presure there will be hard voice and lougd one So please i need help to repair it best wishes Iman
  • imaan_78 Jan 08, 2009
    LG intello washer
    7kg
    wm-1258hd
    do you think if the belt is gone why the machine work ok from the begining and then in the secand stage it had high vioce ?
    Genius:
  • 1,199 Answers
Drive barrel belt may need replaced or adjusted
Posted on Jan 08, 2009
    Sergeant:
    Champion:
  • 304 Answers
If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
    Genius:
  • 1,268 Answers
Please check the belt going to the motor. It could be loose that's why the motor is having problem spinning.
  • Washing Mach... Master
  • 19,396 Answers
Post the model number, if it is making loud noise when drying it can be a bad bearing.
  • 2 more comments
  • Ginko
    Ginko Jan 08, 2009
    Check first if the machine is well in balance, if it is shaking when drying , adjust the feet levels.
    If the washing machine is rumbling with very loud noise on spin,
    then it is probably drum bearings.
    To replace the drum bearings you need to access the back of the machine , remove the belt routing, undo the bearing and replace it , this on a front load.
    When it is the drum bearing you have excessive up and down play in the drum.
    Check also if or the spider at the back of the drum has come away from the drum, or if it is broken.
    Also coins and other objects inside the pump, or inside the drain pump hose can make noise. In this case you access the drain pump and remove them.
    You can find schematics and parts for your model by enering model number here.
  • Ginko
    Ginko Jan 08, 2009
    You need to post the model number see Need help finding the model number on your appliance?
  • Ginko
    Ginko Jan 08, 2009
    It can be the belt, when it is the belt the machine is not even spinning , you rewarded that great guy that told you is a broken belt.
    High pitched noise on high speed is the motor bearing that is gone.
    The motor bearing must be replaced, ask fixya to remove the vote you did if you want more help from me or ask help to the guy that posted the broken belt thing, since you rewarded him.
    Good luck.
  • Ginko
    Ginko Jan 08, 2009
    It is not the belt that guy does not fix washing machines, check the profile here.
    Goodbye, and keep looking for a broken belt.
    Just kidding, I know it is not your fault , it is the system that is bad, have a nice day.
Lg waveforce top load washer that is around 3yrs old. The agitator plate hold down screw (under the chrome cap) keeps coming loose and at the end of the wash the plate is up with clothes under it.
Remove the screw and look underneath the agitator, GE machines have a correct way to put them back so the agitator sits at the bottom of the machine with virtually no gap. Tighten the screw hard. Perhaps you lost a locking washer at some stage?
We moved to front loaders.
Oct 24, 2015 | LG Washing Machines
Elec. clothes dryer turns but won't dry
If dryier is 220 V, phase is burnt out, so it's working on 110V, not enough to heat the air. Check your breaker and electric system or dryier.
Jun 02, 2015 | Dryers
Washing Machin dryier not working probably ?
If the machine works fine except the cycle to the dryer then this can be due to faulty program memory. Try to see if the dryer can be manually selected and started. If so choose another program to confirm or else the fault can be due to program circuit error.
Mar 16, 2013 | Washing Machines
My hoover washier dryer has stopped heating up. I works ok as a washing machine but the tumble dryier doesnt heat up. It is a hoover vhw654d washier dryier
on all dryers you have a hi and a low relay as well as the heater and in some you even have a run tstat check that you have continuity on each side of each of your relays as well as your heater any of these pieces that does not have continuity would be the one that u wuld replace hope this helps if you are not electrically inclined plz call a technician
Jul 21, 2010 | Hoover Dryers
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Not enough Water in Washing machine
i think the problem came from a rins water is little
1- you will check the pressur of water inlet it is easy throuw the soap drawer
2-try to clean the inlet water filter by teeth brush
good work thanks
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WFT7016PP
I have a LG WF-T 7016PP it does not want to go from wash to rinse to spin. I must manualy take it through all the stages. It works perficly on all stages but just does not want to switch over automaticly.
Oct 14, 2008 | LG WFT1071TP Top Load Washer
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
