Question about HP Compaq Presario V2000 Notebook
The speakers on my laptop do not have any sound. I can hear sound only when I plug in headphones. Is there a way to switch speakers? I have a Compag Presario v2000
  • 4 Answers
You could have damaged the sensor in the 3.5 mm headphone jack so your computer does not realize that there are no headphones plugged in. If thats is the case you will have to have the sound card replaced. Another problem could be that the driver is messed up if you recently updated drivers roll back the sound cards driver or update it. Finally you can simply hook up old non usb speakers that use the headphone jack.
Posted on Jan 08, 2009
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
Hello, Could you please assist me on steps of switching speakers on my HP probook 4520s I friend on skype could see me, but still couldn`t hear. Waiting for your fast reply to my issue Thanks in...
sounds like you have built in speakers for your laptop?
you can try plugging in headphones in to the headphone jack on your laptop to see if you can hear any sound.
if you do then you can purchase a 2 speaker set from walmart or any electronics store and hook that up to your laptop for sound.
Mar 10, 2011 | Computers & Internet
Hello, When I connect my headset on my laptop Asus a7sv I get sound but no sound from the speakers. I have Windows Vista en I downloaded the original driver from the asus website. I tried everything....
Most headphone jacks operate as you describe. There is a switch built into the jack that diverts the audio from the speakers to the headphones for "private listening". If it didn't work this way, there would be no way that you could enjoy an audio track or other program with others having to hearing it, too.
You could get around this problem by using an external speaker set and a "splitter cable".
A splitter cable is simply a three ended cable like the one pictured above. The first end has a male plug that matches the jack on your computer - likely a stereo mini plug. The other two ends are usually the same; but the female version. You would plug the splitter into the SPEAKER jack and the laptop speakers would be silenced. Next, you would plug the the external speakers into one of the splitter jacks and then your headset would plug into the remaining splitter jack. You would connect the microphone plug into the MIC jack on the laptop.
You'll have to tinker with the sound levels as there will be feedback issues - depending on how close and loud the speakers are to the headset microphone.
Please rate this reply - and good luck!
Aug 09, 2010 | Computers & Internet
Dell studio xps no sound will come out of the speakers
I assume you mean the internal speakers.
First thing I would try is hooking up a set of headphones. If you can hear sounds thru the headphones then there could be an issue with the headphone jack. (the jack acts like a switch, switching OFF the speakers when you have a plug inside, and switching them back ON when you remove the plug).
If you dont hear sounds thru the headset or speakers, check your device manager, and remove/reinstall your audio driver. You can download the driver at the dell website Support.Dell.com.
Oct 26, 2009 | Dell A525 Computer Speakers
Audio/sound problems
sounds (pun intended) like you have your headphones plugged into the microphone input. See if you can change the spot they are plugged in...
good luck
May 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
My son hears better with headphones we can't hear tv
It is normal that when you plug in the headphones the main speakers are switch off.
You can get the TV modified by a TV repairman to disable the switch that cuts off the speakers when the headphones are plugged in.
May 02, 2009 | ASUS m6n Notebook
Compaq CQ50 Laptop
If the sound works on you headphones the either your built-in  speaker(s)  is/are  bad or more likely the headphone jack itself is broken and not making contact in the speaker position which is fairly common.
Feb 28, 2009 | Compaq Audio card Sound Card
Cannot hear sounds through headphones
if you are able to hear normally from the speakers and not from the headphones possible reasons could be:
the audio is muted or very low
there is a mute switch on the headphone that is turned on
the headphone is not firmly plugged in or is in the wrong site eg microphone
hope it helps
please inform if it helps..
Nov 01, 2008 | Acer Aspire 3680 Laptop
Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
HP Compaq Presario V2000 Notebook Logo
164 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
