Question about Samsung SCX-5312F Laser Printer
Printer will not print
I changed the black ink on my printer replaced it with 21 remanufactured ink jet from inkstop. I did not replace the color because it did not that it needed it.
  • 883 Answers
Double check all latches and access panels that you may have opened to change the ink...the printer may still think these are opened.
Posted on May 31, 2007
Why will my Epson wf7620 not print black ink after replacing the cartridge?
Hi. I don't know if your printer is new or old or if this was the first time you replaced the cartridge or this has occurred after several changes. Most if not all printers will have this occur after replacing a cartridge if the ink had been depleted for some time and allowed to dry up in the jets. Sometimes all it takes is a day for this to happen. I have found that I must go through several cleaning cycles to clear the clogged jet(s). So, try doing a few cleaning cycles and see if that solves the problem. Another cause for a printer not printing after replacing a cartridge is surprisingly a FAULTY or remanufactured cartridge. There should be a program on your computer that displays the cartridge condition, cleaning procedure and ink levels. Give that a look over.
Feb 20, 2015 | Epson WorkForce WF-7620 Wireless Color...
Ink cartridge cannot be recognized
Are the cartridges you are using remanufactured? Some printers are very picky about this and will only work with manufacturer cartridges. What brand of printer?
Jul 26, 2017 | Epson...
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
I only want to print black color but was asked to replace color inks.
Unfortunatly, because its a color ink jet machine you will need to replace the ink to print anything. The way its designed is that it has one printer head for all four cartridges.
When you replace the color ink you will deffinetly be able to print.
Apr 02, 2010 | Brother DCP 115C All-In-One InkJet Printer
Hp 5550 print cartridge light flashing.power light on,not flashin
All HP ink cartridges are dated. If you are using the remanufactured ones the date is not changed and will not work properly at all. By HP ink only and you will never run into this again.
Sep 03, 2009 | HP DeskJet 5550 InkJet Printer
Will not print with black ink
how old is the printer, has it not been on in a certain period of time, if so the ink has hardend on the conductor.
buy new ink, it might help
Feb 12, 2009 | HP PhotoSmart C4180 All-in-One Color...
After cartridge change, the printer will not work
you might not like it, but here it is, it is the truth
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
Aug 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer goes throught the motions of printing, but what comes out is a clean page - no ink
Some of them do. Try going into the printer properties and disabling bi-directional support. This will not allow the printer to check. HP has set some printers to not function if its disabled, but hopefully yours is not one of them.
May 07, 2008 | Office Equipment & Supplies
I had the same issue when I replaced the printer and kept the old cartridges I had just purchased. The OK button I pressed was on the PRINTER not the PC. You dont say the model printer you have. Mine is an all-in-one J6480.
Oct 24, 2007 | HP PSC 1610 All-In-One InkJet Printer
Samsung SCX-5312F Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
