Question about Samsung PCK520R TV
PCK520R 9 year old projection, was fine until last week, now can not keep aligned. I have completed the manual convergence, (20 times) which lasts 5-10 minutes then it goes right out of alignment again. I dont want to go crazy repairing this, any guesses on possible problems and ballpark figure on estimate repair costs? Is this the start of many more problems to come?
    Genius:
  • 1,199 Answers
This sounds like some of the capacitors have burnt out! (does it stay in line then warm up and go out of line? or is it the other way around?) After 9 years there may be many more problems to come with this model TV Projection TVs have a much shorter life span then say a tube tv! (This could cost upwords of $700.00 to fix!)
Please rate this response to your question
Thank You!
Posted on Jan 08, 2009
Hitachi convergence problem
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. Take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests.
Best of luck, hope ya fix it.
Jan 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
My Hitachi Ultrascan is about 8 or 9 years old and it has been the best TV until lately the colors are not lining up. There is a blue arch at the bottom of the screen and over the past few weeks I was able...
Very common in DLP tv u lucky is last it this long.Usally 2-3 years the Convergence ICS are dying will be dead and all it supporting resistors is dead .The convergence is dead,must know how to solders,repalaced Convergence ICs all it resistors.Tries Tv Repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost u 300 for parts and labors.
Jan 15, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Double visions, almost like 3d of all colors
You have a convergence problem, There usually are some limited user adjustments you can make. if these are available on your set they will be listed in the owners manual.
These adjustments are rather complicated. failing that the convergence IC's (chips) may need replacing and a full convergence alignment done. This is best left to a professional as the adjustments require some special equipment
Mar 13, 2009 | Hitachi 50UX57B 50" Rear Projection...
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Need the codes to enter the service menu
First, you will need to fix the convergence problem by replacing
the convergence IC's,then activate auto focus and last,if necessary, enter the servicer mode................T.
Nov 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Convergence and audio problems
1)replace convergence IC's w/best quality. re-align as needed. 2)recheck audio,source and selections in menu. PVAT!
Sep 29, 2007 | Toshiba TN55X81 55" Rear Projection...
Televison & Video Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
