Question about Stanley Bostitch BT200K
Broken plunger on top of piston model sb1850bn
Can it be fixed? and at what price? thank you.
  • 2,176 Answers
First I need the exact model number. And to answer the other question yes it can and I will let you know when I have the info I need. What you need to do if you have taken it apart is look at the cylinder and seals for damage. Let me know
Posted on Jan 08, 2009
Senco 601 plunger sticks when unplugging air line
The piston stop in the head is supposed to grab and hold the piston - I don't believe that is your issue. The problem I think you are experiencing is the head valve not moving freely up and down. There is a funny looking spring under the head valve to push it back - often these get weak or broken causing the head valve to jam.http://senco.com/Documents/Guides/FP601_PC.pdf
Part # KB4393
I would purchase the repair kit #YK0360 which includes this spring - clean and lubricate the tool as you reassemble.
Nov 27, 2013 | Senco & Frame Pro 601 Framing Nailer
Nv45ab won't advance nails
The allen screw/s that you mention are there to plug holes where automatic equipment would normally connect (such as automatic nailing machines) . This is only a plug and should not be driven in too far. I have also seen allen screws installed in the head to repair small crack/s.
Jan 22, 2013 | Hitachi Air Tools & Compressors
Replacement starbucks french press plunger
Yes. I would like that plunger. Our top lid knob also came off. Right now, tho', it is the rubber on the plunger that is failing. Don't think we can fix that.
Dec 22, 2012 | Starbucks Coffee Makers & Espresso...
Senco nailgun sn4 plunger doesn't retract
The driver will not retract if the driver is bent, piston oring too loose or too tight or the check band is loose or missing. Easy test, remove air and push the piston to top of cylinder. It should move up with very little effort. If hard to push, oring too tight or driver bent. If piston moves too easily and drops back down under its own weigth, oring too loose. If easy to push and stays suspect check band (check band is located on the outer lower part of the cylinder. Looks like black rubber band or series of orings that fit over series of holes. ). If the band is split or broken, replace with series of orings to cover all holes, or use any rubber like bicycle tube. Good luck with your repair.
Sep 28, 2012 | Air Tools & Compressors
I have a Senco Frame Pro framing nailer. The plunger is sticking in the
Check the drive pin for burrs and file them off. Check for worn piston replace if necessary. Clean the air return hole in the top of the piston cover. Add oil if manufacturer recommends it.
Mar 24, 2012 | Senco Air Tools & Compressors
Model wl660800aj wont build any pressure hardly 10min 10psi took unit apart check valve appears to work ok valve sheets not broken but cylinder has light scouring and slight play no kind of seal apparent...
The piston should be tight in the cylinder and there should be no play between them. There should also be a ring at the top of the piston to seal it in the cylinder. You need a piston/cylinder assembly, part number WL211000SJ to fix your problem. They are a common failure item on oilless compressors and you can only buy them as an assembly, the parts are not available seperately. The part is available on www.ereplacementparts.com but shop around the web, compressor parts aren't cheap and prices and shipping varies.
Aug 19, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a haubold-kihlberg PN1414G, staple gun needing repairs, any suggestions? The plunger goes down, but does not return.
You have a broken piston bumper (the nylon insert surrounding the part of the driver blade that is inside the piston. You can purchase the piston on it's own or complete with the driver attached. That'll be it cured. It's a common problem with the G tacker.
May 31, 2010 | Tools & Hardware - Others
Low compression on my kxf250.2004 bike doesnt kick,bike runs fine
It sounds like time to do a top end job. The head will need to come off, then the valves should be re-seated. Carbon should be removed from the head and piston crown. Since you did not mention any engine smoking, I assume the rings are okay. If you are going to do anything with the cylinder, piston and rings, now would be a good time. But remember, if it isn't broken don't fix it.
If you do the work yourself be sure to start with the piston on TDC compression. Note the timing marks stamped on the overhead cam. The piston and marks will need to be in the same position when reassembling.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock.
www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Jun 05, 2009 | 2004 kawasaki KX 250 F
Replacing driver unit in bostitch 23 gauge pin nailer model hp118k access through top of frame unit or bottom
Access is via the head cap. Remove the 4 screws and carefully take off the top. Be careful the head plunger does not fall out and keep it upside down.this way you are sure how to put head back on.
tap top of body against your hand to drive piston up and remove and replace piston assembly.
good luck
Apr 14, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Water too slow
Most probably the plunger has unscrewed. You need to remove the plunger from inside. Remove the bottom circlip and remove that pin so that will be disconnected from the plunger mechanism. Remove the bolt and washer on top of the plunger, remove the group and than smartly tap with a rubber mallet to remove the plunger mechanism from below. You will probably notice that the shaft is unscrewed from the ceramic plunger though not all the way. Tighten this and clean inside the group. replace the mechanism from below and replace the sieve with the rubber o-ring seal - you will have to use a screwdriver or similar implement to secure the o-ring in the space. Replace the pin for the handle insert the circlip and replace washer and bolt. You are good to go.
Sep 13, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Stanley Bostitch BT200K Logo
125 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
