Question about Compaq Evo D500 PC Desktop
Thanks for responding
However I have searched through bios and have found nothing pertaining to sata... i have primary and secondary ide controller disable/enable.?
    Problem Solver:
  • 12 Answers
Oh sorry your PC dont have any SATA controller...
listen, try to check if the BIOS recognize the HDD...(you will see something written near the PRIMARY IDE like in these pictures:
http://img80.imageshack.us/img80/4849/cdburner11rs0.jpg
http://img54.imageshack.us/img54/7770/mtkflashpb8he.jpg
Posted on Jan 08, 2009
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Raid settings, i one to set sata drive as primary and ide as secondery
First connect the SATA to port 0 Sata does not have any Primary or secondary port, It has ports SATA0,SATA1,SATA 2, 3 and 4(depending upon the number of ports available on your motherboard), Connect the SATA to port SATA0
Then connect another Drive to IDE 2(secondary). Normally the IDE port closer to the RAM is primary.
To confirm the connection is correct you can look in the BIOS
Please let me know if this information is helpful to you. If you find it helpful please do not forget to rate it.
Thank you for choosing Fixya
Oct 08, 2009 | Intel Motherboard
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
How do I make my Acer E661GXM mobo read an IDE primary HDD and a SATA secondary HDD?
I didnt got exactly what ya want ...but I have some idea...
probably it says something like ( at identification on boot ) primary ide controller.....cd/dvd...... secondary ..ide ...hdd...... sata controller hdd....
this is not an issue of which one is primary ans so ....cause those are 2 completely different bus-es ...and the only way to make your ide hdd be read like primary ...its to change the plug with the one from the cd /dvd..drive ..
the rest doesnt matter cause it s a different controller...
Apr 11, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
When my computer was started in monitor display MBUltra133 (tm) BIOS Version 2.20.0.1. MBUltra133 BIOS is not installed because there are no drives attached. SiI 3112 Serial ATA Host Controller BIOS...
If you are looking at Device Manager, the computer must be working to some degree. Since there are no drives on the SATA controller, you're probably using an IDE drive and don't need the SATA controller anyway. Disable it in the BIOS. And get more memory.
Dec 11, 2008 | Computers & Internet
Computer won't run windows and come up with a trap-handler error
on the IDE Port, set the jumpers to the hard drives/cdrom on CS(Cable Select) this lets the BIOS and the ribbon cable decide which is primary (Master) and which is secondary (Slave) on that IDE cable. if they were configured wrong you would get an error.
If the IDE channel is no good, try switching the primary and secondary IDE ribbon cables.
May 26, 2008 | Intel Motherboard
Maxtor diamondmax plus 9 6y080l0
If you have you primary HDD set on Cable select, and the secondary HDD is set on anything other then Cable select (with the jumper settings on the back of the HDD) then there will be an error.. Also, if you primary is set to master/slave and the same for the secondary, it will cause problems.
Another thought, if one of your drives is SATA and the other IDE, if the IDE is set to master, there may be an issue as SATA HDD's will try to post as the master drive
Mar 24, 2008 | Maxtor Hard Drive
Secondary IDE not working
Try to check if there are some capacitor has been damage. Replace the capacitor in each specific specification. You can do it yourself by using soldering iron.
Hope this is helpful to you.
Please vote me if I'm done correct solution.
Oct 30, 2007 | ASUS A8V-VM Motherboard
Compaq Evo D500 PC Desktop Logo
71 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
