Question about Zenith IQB36B42W TV
TV won't turn on.
Hello, I am hoping that you can help us. After working just fine, yesterday the tv wouldn't come on. We unplugged it which normally worked after a storm or something like that, but this time it didn't work. It will not turn on either by remote or on the tv itself. A couple of times, after unplugging it, it clicked like it was coming on and then clicked right back off. When hitting the power button on the remote it feels like there is just nothing there. We also pushed a lot of buttons on the remote because it seemed like it was "locked up". Which did nothing. Can you help us? Thank you very much. Mary Kay
  • Mary Kay Wall Jul 27, 2007
    This is a belated thank you for your help. I had total hip replacement and couldn't get back to you.
    Do you have any ideas on where to get that part/switch?
    Thank you
    MK Wall
  • 3 Answers
It sounds like you have problem with the switch on the tv itself. try opening the front panel where switch is located and check wiring or maybe change the switch which you can get it online.
Posted on Jun 01, 2007
SOURCE:
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
My Toshiba laptop won't turn in. Yesterday I was
Unplug, remove battery, plug in reboot. OR, try a System Restore to a date before this issue. Have you cleaned the fan, vents, heatsink recently? Is it overheating? It would be helpful if we knew the Toshiba Model number and the OS you are using.
May 06, 2013 | Computers & Internet
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Hello have a problem with tv Model is: lg
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6281
The above link goes to lg's website describing the red flashing light where the power switch is, and
another switch down below which can turn that light off.
Try switching that other switch below off so the light turns off. Then, switch it back on.
If that doesn't work, then service should be scheduled for this discontinued model.
Hope this helps on your lg tv.
Jun 29, 2010 | Compaq Presario 5000 PC Desktop
Viewsonic not working...
Hello mike this problem could either be that your main board is faulty or the most common problem would be the power supply board which is giving you this problem, what i would suggest just to be on the safe side is for u to do a hard reset on your tv set just incase it is a tv setting problem, disconnect your tv set for a period of 4 hours than plug it back in and see what happens, if that does not work than your problem is more than likely a bad power supply board hope this helps thank you.
Aug 15, 2009 | ViewSonic N3735W 37 in. LCD TV
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
32 in ilo tv not turning on
The power supply most likely failed on your TV.
I service these power supplies.
Let me know if you need further assistance. my email is jah2mil@hotmail.com
May 20, 2008 | iLO 3200 32 in. LCD Television
Open Questions:
Zenith IQB36B42W TV Logo
111 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
