Question about Mintek DTV-263 26 in. LCD Television
I have mintek dtv 265-d lcd 26in
The tv will power on goes straight to dvd mode.\
none of the on board controls work
trying to change it so i can use the tv or hdmi
please help me
  • businessguy2 Feb 09, 2009
    i bought a remote off ebay the rc 600.when i got an tried it .it will onlty turn on the tv or off
  • 362 Answers
Have tried the remote, most new tvs have a control panel lock that can accidently be activated, it usually takes the remote to undo the lock.
Let ne know.
lone99star
Posted on Jan 08, 2009
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
Dec 07, 2015 | Mintek DTV-263 26 in. LCD Television
Mintek tv/dvd combo dvd is stuck, volume is stuck, chanel is stuck
The model DTV-263/265 has this common problem, the main board will have to be replaced.
Oct 30, 2009 | Mintek DTV-263 26 in. LCD Television
Mintek 26in lcd tv
This unit has had a component failure on the main board.You can find parts for this model on e-bay. Have someone check the television for you and see if the failure is caused by minor failures. This could be from cold solder joints to bad capacitors. These are easy repairs. the way to do these repairs can be found on you tube,use the search engine to look for capacitor repair on lcd televisions and monitors.You can find parts for this television at e-bay.Put the make and model number of your television and the repair part number you are looking for. The search engine will bring all the parts available. You can also check this website for repair parts. http://www.discount-merchant.c/SearchResults.asp?Cat=&Search=PCB&RefineBy_Manufacturer=MINTEK I hope this information will help you with your problem.
May 28, 2009 | Mintek DTV-265-D 26 in. LCD TV
Mintek -dtv-265-d stuck in DVD mode
These units have had a failure in either logic board or the main board. The only way to repair these units is to get replacement boards and see if this repairs the problem. You can try to source these parts at e-bay. Use the search engine, plug in the make of you television model number, and part number of the board you think you need for the repair.The search engine will bring up all available parts for you.You can also try this website for parts. http://www.discount-merchant.com/SearchResults.asp?Cat=&Search=PCB&RefineBy_Manufacturer=MINTEK I hope this information is of some help to you with your problem.
Mar 15, 2009 | Mintek DTV-265-D 26 in. LCD TV
TV w/ built in DVD
Hi maybe this might work on your dtv,try load a post card the size of a dvd and hold it in then try the source button to change to tv mode.It worked on my dtv-265-d now all i need is to get a remote control.
Aug 09, 2008 | Mintek DTV-263 26 in. LCD Television
On-screen Menu
Actually, it is not a Projection TV Problem. The problem is with a Mintek DTV-265 26" flat screen digital TV (not projection). I have not yet resolved the problem by unplugging the set, pressing the eject button and replugging in the set nor have I had any other suggetions. The manual clearly indicates Mintek DTV-265 26" (not Mintek DTV-263) but I feel they are very similar; however, the manual does not mention losing/restoring the on screen menu.
Feb 28, 2008 | Mintek DTV-263 26 in. LCD Television
Mintek DTV-263 26in with No Color
please locate with your remote and change from NTSC to PAL or from PAL to NTSC while whatching cable
Jan 09, 2008 | Mintek DTV-263 26 in. LCD Television
Mintek 26" lcd hdtv dtv 265-d
mintek dtv-265-d THE TV WILL ONLY PLAY CHANNDEL 34 THE REMOTE WILL ONLY TURN ON OR OFF IS THERE A SERVICE MANUAL OR A REPAIR!!!!!!!!!!!!!! rad
Oct 09, 2007 | Mintek DTV-263 26 in. LCD Television
Mintek DTV-263 26 in. LCD Television... Problem:
I suggest you go to their website at: http://www.mintekdigital.com/user_man.asp The DTV263 is not available online, but the DTV323 is there and this should be the 32" version of the same set. Download the manual for the 32" version.
Aug 20, 2007 | Mintek DTV-263 26 in. LCD Television
Mintek DTV-263 26 in. LCD Television Logo
205 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
