Question about Linksys Computers & Internet
Cannot connect to wireless
Hit the Cisco Ikon and it reset the security , i hand a name set up but it does not recognize it anymore
Hi Daniel
Try to delete the wireless profile on your PC and connect again.
Ricardo
Posted on Jan 08, 2009
I bought a cisco valet router used and do not know the password , how do I change the password
On the back of the router is a reset button. Press that in for 5-10 seconds. It will reset to factory specs. Once you reset the Valet Hotspot, all of its customized settings (network name, wireless security, etc.) will be erased and the hotspot's IP address will be reverted back to 192.168.1.1, with a default password of admin and no username.
Jul 30, 2016 | Cisco Computers & Internet
Tip
How to Configure your Linksys router with wireless security
Launch your Internet Explorer, Netscape or your Mozilla.
On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
To reset the router to factory default
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
Cisco Interface (If your Setup page has a Cisco Logo)
Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
Under Setup > Click WEP Key Settings or Edit WEP Key Settings
Using passphrase 64bit
Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
For manual key entry of 64bit encryption:
Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
(e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
Using passphrase 128bit
Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
For manual key entry of 128bit encryption:
Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
(e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
on Jan 06, 2010 | Computers & Internet
Tip
Changing Channels on your Routers.
You may try to use different channels on the router to get a better signal. Follow the steps below how to change channels on your router:
1. Connect your computer to the router via an Ethernet cable and open your web browser (normally Internet Explorer, which can be found on your desktop or on the Start Menu in Windows XP).
2. Once your browser opens, input http://192.168.1.1 into the "Address bar".
3. You'll be prompted for a User Name and Password. Leave the User Name blank and type in admin as the password.
Cisco Interface (if the setup page has a Cisco Logo)
Go to Wireless Tab
SSID: (e.g. Vic or your name or last name)
Channel: Any from 1-11
Then hit Save Settings.
Regular Linksys Interface (if the setup page has no Cisco Logo)
Under Setup:
Then hit Apply
After doing this you should have a better Wireless signal from your router....
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
Cisco router
CISCO/Linksys -To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 21, 2013 | Cisco 4033836 - Model Dpc3925 8x4 Docsis...
Tip
How to change Wireless Channel on LInksys Routers...
Try to use different channels on a wireless router to get a better signal. Follow the steps below how to change channels on your router:
1.Connect your computer to the router via an Ethernet cable and open your web browser (normally Internet Explorer, which can be found on your desktop or on the Start Menu in Windows XP).
2.Once your browser opens, input http://192.168.1.1 into the "Address bar".
3.You'll be prompted for a User Name and Password. Leave the User Name blank and type in admin as the password.
Go to Wireless Tab
SSID:(e.g. Vic or your name or last name)
Channel:Any from 1-11
Under Setup:
Then hit Apply
Hope this help everyone.
My wrt54g stops wireless connections. hard wire remains ok but I have to unplug it to get wireless connections back
Hi Friend,
Please follow the steps in order resolve the issue.
1.Refer to the link http://homesupport.cisco.com/en-us/wireless/linksys
2.Enter the model number and hardware version and download the latest firmware. Save it on the desktop.
3.Open web browser and type 192.168.1.1 and hit enter.
4.If you have not changed the default password then type admin as password and leave the username blank.
5. In the router setup page click Administration and then click Firmware.
6. Click browse and select the file you have downloaded and hit Upgrade.
7. Turn off the router for 30 seconds once the upgradation is over. Switch it on after 30 seconds.
8. Open web browser again and type 192.168.1.1 and hit enter.Enter the password.
9.Click Wirless and fill the sections as mentioned
*Wireless Network Mode: Mixed
*Wireless Network Name: Any name as per your choice.
*Wireless Channel:6-2.437 GHz
*Wireless SSID Broadcast: Enable and click Save settings.
10. Now click Wireless Security and fill the required fields:
*Security Mode: WPA Personal
*WPA Algorithm: TKIP
*WPA Shared key: Any ten digit number (please note it down, as you will require this to connect your wireless devices). Then click Save settings.
11. Click Advanced wireless settings and fill the fields as:
* Beacon Interval: 75
* Fragmentation Threshold:2306
* RTS Threshold:2307 and click Save settings.
Turn off the router for 30 seconds and switchit on. Use the shared key as the password whenever you want to connect any wireless device.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 08, 2010 | Linksys Wireless-G WRT54G Router
I have a second hand linksys router, but dont have the software or CD to install it, how do perform the connection to my PC? thank so much for kind help
Hi Friend,
Please follow the steps in order to resolve the issue:
1.Connect the wire (which is coming out from the modem) to the WAN/Internet port of the router.
2.Connect the computer to either of the four LAN ports of the router.
3.Turn on the router and press and hold the RESET button for 30 seconds. Turn off the router and turn it on after waiting for 30 seconds.
4.Type 192.168.1.1 in the address bar of Internet Explorer and hit enter.
5.Leave the username blank and type admin in password.
6.In the setup page make sure Internet Connection type is set to"Automatic Configuration"
7.Click MAC address clone and select Enable and then click the tab CLONE. After that click Save Settings.
8.Now click Wireless(to configure wireless) and fill the sections as mentioned
Wireless Network Mode:Mixed
Wireless Network Name:As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enabled and click Save Settings
9.Click Wireless Security and fill the sections as mentoned
Security Mode-WEP
Default Key-1
WEP Encrypion-64 bits 10hex digits
Key1-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
10.Since it is a second hand router, I would suggest you to please upgrade the firmware
Please follow the link: http://homesupport.cisco.com/en-us/wireless/linksys/
Enter the model number and click the Download tab. Then enter the version number(which you will get once u turn upside down the router) and download the firmware and save it on desktop.
11.On the router setup page click Administration and then click Upgrade Firmware.
From here upgrade firmare and turn off the router for 30 seconds. Turn it on and enjoy.
Regards
Chiranjeet
Jun 13, 2010 | Linksys Wireless-G WRT54G Router
How do i install a password in my wireless rauter, to prevent intruders access? Linksys/Cisco 192.168.0.1
Hi Friend,
In order to resolve the issue please follow the steps:
1.Please connect the router with a computer
2.Type 192.168.1.1 in the address bar of the Web browser(e.g-Internet Explorer) and hit enter
3.Enter the Username and the Password (defualt password is admin and leave the user name blank)
4.Now on the Router setup page click Wireless tab and fill the sections as mentioned:
Wireless Network Mode-Mixed
Wireless Network Name-As per your choice
Wireless Channel-6-2.437GHZ
Wireless SSID- Enabled and click Save Settings
5.Now click Wireless Security tab.
6.Select the Security mode as WEP and fill the sections as mentioned
Default Transmit key- select 1
Key1-Enter 10 digit or 10 letter password(e.g-your telephone number) and click Save settings.
Now turn the router for 30 seconds and after that turn it on.
Try to connect your wireless devices, it will ask for a password which will determine that your network is secured from intruders.
Regards
Chiranjeet
Jun 02, 2010 | Linksys Computers & Internet
Can't get to 192.168.2.1 anymore. why?
You need to find the reset button and press it with a needle head, untill all setting are reset. Power cicle your router and if you are using a modem. Try again. You shouldn't have any orange lights on your router. Now go to your computer, and you will find your wireless rounter name, try to connect to it, and it will ask you for your pin number. You can find the pin in the bottom of the router. After typing the router's pin, it will ask you for the security settings and stuff. Once done, you should be good to go.
Thanks,
Wais
Mar 12, 2009 | Dynex DX-E401 Router
Computers & Internet Logo
60 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
