Question about LG LMV1630ST Microwave Oven
LG MS194A Not lighting up and heating up
I have an LG MS-194A Microwave oven which went off two weeks ago and could not power up. Opening it up I found the Fuse clamps borken. I soldered in both clamps and the oven is powering up with the control panel on and the timer working. The problem now is that the lamp does not light up and the oven does not heat up.
What would be the problem now??
  • sibonan Jan 13, 2009
    Is it OK to test the lamp with a 12V battery to check if its working.
    Test all switches by following the instruction and found them OK. How do I test the lamp/bulb??
    Can I remove it and test it using batteries?
  • LG Master
  • 9,098 Answers
It is probably a bad door switch (upper or lower) or one of the switch mounts is damaged or misaligned.
Some help here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
An exploded view is here.
Other exploded views and parts lists are here.
Since you are in PNG, you'll have to find parts locally or maybe via Stokes in Australia.
Posted on Jan 09, 2009
  • William Miller
    William Miller Jan 14, 2009
    As long as the battery voltage is less than or equal to the rating of the bulb's voltage, yes.
    If it's a halogen type, be sure to wipe the bulb off with a dry cloth before reinstalling it as oils from the skin can cause them to overheat.
LG MS-1943ALT Micowave not working, light, fan and turntable all work, no heat
From the decription that you have provided, the magnetron is highly suspect and is the most expensive part to replace, cheaper to replace the microwave oven in the long run.
Sep 06, 2011 | LG Microwave Ovens
I have a LG Microwave that shuts itself off before its done cooking any comments? The lights and clock are still on so its still getting power
The microwave oven has a temperature sensitive thermal fuse, if the magnetron overheats "heats food" it shuts that sector down until it cools down, "up to 30 minutes before it will reset" sometimes the thermal fuse becomes defective opening up because it has become intermittent over time. This is a tricky problem to diagnose and should be checked by somebody who is familiar with these types of devices.
Jun 05, 2011 | LG Microwave Ovens
My LG (model ms3446vrl) wont heat anything. Everything else works fine. It is only 2 weeks out of warranty too, not happy. Lynda
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 04, 2011 | LG LMV1680ST Microwave Oven
Microwave Oven LG MS-256EL/MS-257EL The oven does not work in microwave mode however the halogen and the fan assisted plus grill do work.
heatman101
Nov 16, 2010 | LG Microwave Ovens
Microwave not working (generating heat)
Please check the door switch for proper operation.
May 19, 2010 | Frigidaire PLMV168 Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
LG microwave not heating
If there is no power at all check thermal cutoff and control board.
Mar 18, 2009 | LG LTM9000 Microwave Oven
LG MS-3444DPS microwave - spins but doesnt heat
Chances are you have shorted or blown high voltage rectifier diode.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/diode.html
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Nov 21, 2008 | LG LRM1250 Microwave Oven
Change of lamp in LG microwave oven MS-194A
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Sep 11, 2008 | LG Microwave Ovens
LG LMV1630ST Microwave Oven Logo
179 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
