Question about Toshiba Satellite A105-S4004 Notebook
The screen flickers and scrolls and is very messed up. im trying to figure out if its the lcd screen or the inverter board
  • mgabrick404_ Jan 11, 2009
    but when i had it taken apart i would gently flex the lcd screen and it would go crazy...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
If the screen at any piont work normally its the inverter. they can be bought on ebay for 10 dollars
Posted on Jan 08, 2009
My flat panel is flickering in the right side when it's just turned on
You may very well have a defective LCD panel Henrik. Samsungs are know to have premature LCD panel tab failures. There are several ways to verify this. I would wait to after the set stops acting up and I would spray the upper right side of the screen with "freeze" spray. If the flickering comes back, you have a faulty LCD panel tab. The only true fix is to replace the panel, big $$$$. There are several youtube videos showing you how to patch the problem.
Apr 03, 2013 | Samsung Televison & Video
47lh90 blinking red light and flickering
the regulator for the Inverter supply would be the first thing i would suspect if the voltage drops then picks up again. Then I would also check the transformers on the Inverter that are in line with the area of the screen that flickers.
Mar 22, 2013 | LG 47LH90 47 in. HDTV LCD
Upper sise of screen flickering problem
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation.
http://www.tech-faq.com/how-to-repair-a-laptop-screen.html http://www.laptop-repair.info/laptop_screen_repair.html b> Hope this helps.
Jan 21, 2013 | Lenovo IdeaPad S300 59359327 Silver Gray...
My alba lcd22advd keeps flickering while on fav channel
check for a dry joints at the inverter board for the screen back light, which may have loose contact.
Aug 10, 2012 | Alba LDVD1538WDCH LCD TV
Acer aspire 8935g flickering screen on startup..even i see flickering when i go in bios setup...dos mode is flickering... kindly help... Thanks.
This is not a software problem. This is an hardware one. You have to replace the LCD inverter or to repair the existing one. The most common problem in the inverters is the age of capacitors. Im most of the cases if you replace the capacitors the problem is solved. This is working for any kind of LCD monitors and LCD television set. If you are a handy man you can fix it yourself by consulting the internet to see how it looks the inverter and where can be localized, how it looks a capacitor and where you can buy it, etc. If not a handyman try to ask a tehnician for help... Good luck!
Jan 26, 2011 | Acer ASPIRE 8935G-904G100BN LAPTOP LCD...
Our flat screen television picture has gone black, we still have sound. Can this be fixed or is it time for a new tv
Yes,this tv can be fix.The tv have flicker of picture a few sec.than dies,have sound olny lelf?Yes,than the 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help LCD screen to have a backlight to produced a picture.Tries websites like Shopjimy.com,Ebay.com to buy those 1 or 2 long refurbish LCD inverter boards for the replacement.
Sep 09, 2010 | Televison & Video
Samsung 32 inch LE32R73BD 3 yers old, no picture but i have sound
Tv turn on now,have flicker of picture few sec.than dies.Have sound left only?Yes,than the 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
The picture suddenly goes off, audio still on. Coes back on after turning off then on again. Tried resetting with remote control but problem persists
Turn tv on now,have a picture flicker few sec.than died.Have sound left only?Yes,than the 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Sep 09, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
When tv gets powered on the screen flickers for about one second then goes blank
The tv 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Aug 05, 2010 | Toshiba 40G300U TV
Flickering screen. Picture is darker and the left side of the screen(when looking at screen) is weaker than the right side. Flickers for about 15 seconds then screen goes black
Ur LCD inverter board is dying.Must replaced this board,to get picture back good.Tries Shopjimmy.com,Ebay.com for the board.It a long board.
Jan 10, 2010 | Astar LTV-3001 Television
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
