Computers & Internet Logo
Posted on Jan 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need key code (WEP) for D-Link router to type into a second computer for wireless access
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jan 08, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
Helped
1789
Points
18
Just use your phone number for right now, if it works then u can change it later on to a different number and letter combo.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 144 Answers
Anonymous
Expert
Level 2:
Mentor:
Answers
144
Questions
Helped
42615
Points
352
The code was at one point set by you and there isno standard code
1helpful
3answers
How do i find wep key
Connect your router to computer with lan cable then you can access it with default link http://192.168.1.1 then type user as "admin" and password as "admin" or blank or "password" then you can see settings of router. Click on wireless then wireless security WEP key note down the code it is your password to connect wireless. Let me know if you need further assistance. Thanks for using FixYa.
1helpful
How do i find out my wep key password
Welcome to Fixya. If you need your Wep Key (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key (Wep Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
2answers
I am connected to my router on my laptop, and I am trying to connect a second laptop to the same router. Problem is I did not write down my WEP password and it is grayed out so I cannot retrieve it. I...
Welcome to Fixya. If you need the WEP key or Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blankand the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Wep Key. The Network Key or Wep Key serves as a password or security code on your network to make it secure.
Thanks for using Fixya.
3helpful
2answers
Want to connect wireless printer but i need WEP key so the printer can connect on same wireless connection
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
My friend has a wireless connection & wants to share her wep key with me so I won't have to buy time warner! She has XP, I have Vista. I can't find how to access her Linksey's wireless or find where...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then click on WEP and there is code it is your password to connect wifi. Let me know if you need further assistance. Thanks for using FixYa.Add a comment
1helpful
I gave someone my wep key and now i want their computer off my access. How do I remove their computer?
You can change the WEP key on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
1helpful
3answers
I need my wep key for my linksys router
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for step by step instructions
1helpful
Dell wireless router WRTA-108GD... How do I determine Security key # to activate on new laptop?,,,,, Thanks..Keith
You can secure your wireless network wit WEP or WAP code.
For know your security key Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
The old password is in * or # format so you need to enter new password.
Let me know if you need furhter assistance.
1helpful
2answers
HOW TO FIND WEP KEY WGT624 WIRELESS ROUTER
a router by default is open to all network.To set a key you need to go into a browser and type 192.168.*.* depending on your router it will differ from others.Then once into your router setting you can create a password and wep key according to your wants.It is not a difficult task but you need some patience and a bit of struggling with some google help will solve this problem.
1helpful
2answers
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Grand Canyon Tech
Grand Canyon Tech
