Question about Arcam AVR-200 Receiver
Receiver died out
I own an AVR200 receiver, I used it on Christmas for about 4 hours and it just died out on me. Could this be a fuse problem? the power LED light is showing a green color which is normal but, the rest of LED screen does not show any longer. Please help.
Elvis Alvarez
  • 2,071 Answers
Maybe a fuse in amplifier section is blown out already,caused by busted four darlington transistor or if this amplifier use a STK IC. This is the common problem of the amplifier,try to check this if ever a defected then replaced it with a identical rating.
Hope it may help you;
Posted on Jan 08, 2009
Arcam AVR200. Buzzing sounds in all 5.1 speakers. Gets louder as volume is turned up. Tried all sorts of different things - different power source, 1 speaker, different modes.
I had the same problem. I was told by a sales guy at a high end audio store that I should try using a 3-Prong To 2-Prong Adapter. I went and bought one. I plugged it in and no more buzzing.
you can find them at HomeDepot, Lowes or dollor store.11_25_2012_6_28_23_pm.jpg
Jul 12, 2011 | Arcam AVR-200 Receiver
Can you charge the 1440 using a usb to the computer?
For the software version: In the menu go to "Product Information" you will find it there.
If your GPS receiver has power pin port and a USB port the internal battery cannot be charged using your computer. You must use the supplied vehicle power adapter to charge the receiver's internal battery.
If your GPS receiver only contains a USB port it can be charged by your computer however we recommend using the supplied Vehicle Power Adapter.
Charging the internal battery using your computer may take up to 12 hours. Charging the internal battery using he supplied Pehicle power Adapter takes 4 - 6 hours. The receiver can be powered on or off while charging.
Most other answers can be found below.......
Feb 17, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Been having issues with my 625. I noticed in the diagnostic listing...boot recovery says 2.. What exactly does boot recovery mean in terms of problems with the receiver? Sounds to me like a harddrive...
If your receiver is going into boot recovery - this is a DOS based program- you will be better served by getting it replaced. On newly installed receivers this can occur as a result in the manufacturing process or re-manufacturing process and not cause further issues.
Thanks for using Fix
Oct 08, 2010 | DISH Network DVR-625 DTV Receiver /...
ViP722k receiver, continuall freezes and restarts
Hi Mike Houston of DISH Network customer service here.When the 722k freezes and restarts on and off, the receiver may be in Bootrecovery, this process can go from 45 minutes to 4 hours. If after 4 hours itstill is going on and off and with the steps you have done we would need totake a deeper look and go through the menus of the receiver.
May 09, 2010 | Televison & Video
first, charge it overnight. then go to and look for firmware updates. install them and you should be set
Mar 07, 2009 | Garmin Nuvi 660 GPS Receiver
New Garmin 260 W won't do anything when plugged in.
Your PC may not be able to charge it. If it does it's only a trickle charge. May take a day or two
The Garmin cigarette lighter charger take 4 hours.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
Subwoofer blows internal fuse when receiver is turned on
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
Dec 12, 2008 | Bose Acoustimass 16 Speaker
Power won't stay on
This is called power cycling and the receiver must be replaced yet again as it has a faulty power supply. Unfortunately this is the only solution to resolve this issue other than upgrading the receiver type or going to the competition. Hope this helps you out. Thanks for using Fix Ya and let me know if I can further assist you.
Dec 03, 2008 | DISH Network DVR-625 DTV Receiver /...
DTV H20-600
You could check the voltages yourself to see if they are low. The horizontal polarity needs about 19 volts and the vertical polarity about 14 volts to work properly. If those voltages are lower by 25%, the receiver might failed to scan and that is when it locks up because is trying to find signal. The other issue could be a defective power supply if the receiver does not work after that 4 hours. There could be some capacitors that lost their dielectric strength causing the drop in voltage.
Let me know if you need further assistance.
Nov 01, 2008 | Philips DIRECTV H20 DTV Receiver
Dvr recording skip sound
probably a dying hard drive, but could just be corruption, delete all effected recordings, monitor, if issue continues delete all recordings unplug receiver for 10 minutes, monitor new recordings if continues receiver may need to be replaced
Jun 25, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Arcam AVR-200 Receiver Logo
350 people viewed this question
Top Arcam Audio Players & Recorders Experts
Sock Puppet
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
