I am considering purchasing a front load GE washing machine. I am curious if the inner drum and the outer drum are both metal? I am comparing the advantages of the GE front load with the Miele and the Whirlpool front load machines. Thank you, Jeanne
    Novelist:
    Champion:
  • 220 Answers
I can't speak for all, but my GE front loader has a stainless inner and a plastic outer tub. I don't know what the benefit of a all metal would be. The plastic outer tub seems to hold up fine, The only problems I have expereinced with the washer tubs were the bearing going bad after the seal failed, but its 10 years old. I consider that normal wear.
Posted on Jan 08, 2009
While spinning, it made a loud noise but finished washing the load while continuing to make the noise especially while spinning fast.
Hi Chantal,
In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
Sep 14, 2015 | Miele Touchtronic W1213 Front Load Washer
Inner drum of GE front load washer is very loose and is banging against the sides of the outer drum.
The rear spider shaft has broken it can be repaired. but I'm not 100% on lg units a lot of newer washers have a complete tub unit now it's all sealed in would need to see the machine with the lid off.
Dec 10, 2012 | Washing Machines
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
I have a hotpoint aquarius washing machine, with the belt off and you lift the inner drum there is a lot of play the pulley wheel that the belt goes round has been cutting into the back of the plastic...
Hi.
It could be a combinatrion of both things, as bearings often fail, and the drum supportt is prone to corrosion and metal fatigue, which would give the exact symptoms you describe.
Either way it involves a complete stip down of washer to determine the exact problem
Feb 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine making vey load something is wrong noise. Called repair man, he states too young (2yrs) to be a drum problem and okay to use just do smaller loads. On 2nd load found metal shavings..have...
The rear half of the outer tub that contains the rear metal bearing has loosened so much that the inner drum has sagged and is rubbing on the front half of the outer tub. You need to see if this is under warranty. There is usually a 5 year warranty on the outer tub and a 10 year or a lifetime warranty on the inner tub. When I do this repair, I replace the rear half of the outer tub and the inner drum since it's under warranty anyway. The repair is the most difficult and time consuming repair possible on that type of washer. It needs to be done by an expert, not just your average washer repair guy. It's not rocket science, but you have to take EVERYTHING apart and it takes a long time and you've gotta know a few things about the machine in the first place. It's not fun. If it's under warranty for parts, expect to pay between $75 and $200 for labor. If the parts are not under warranty, then throw it away. They're $500+ for the parts.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Removal of rubber seal
I take off the top cover unplug machine 1st ..Safety...Then take offretaining ring on inner drum /also ring on outer drum remove boot seal..Check utube video, explains in good detail...
Oct 07, 2009 | GE WBVH6240F Front Load Washer
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
Dark Spots on clothes
There may be some pieces of mat stuck between the inner and outer drums. The quickest way to remove this is to remove the drain hose that leads from the drum to the pump and feel around the bottom of the outer drum and remove any foreign objects that may be stuck in there.
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
