Question about Hammering
Fuse problem hi i have a very old electric fuce box..it has brackets that hold the big brass fuses does any body no were i can get a nother one ?...the name on my main fuse box is taylar electric can any body help?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • 112 Answers
From my experience, u will have to call some electric supply houses and ask them for it, sometimes u can order the older fuse holders.
more than likely u will have to to look at some salvage places for it, u can ask the supply houses if they know who would have it. it is something that u will just have to track down and if all that fails u will have to replace the box.
Posted on Jan 08, 2009
Hi my 1.3 bantham roadcam dacebord and tale lights do not work. It seems that the fuses is right
Always check fuses with test light. After that perhaps the main switch.
Feb 15, 2015 | Cars & Trucks
2011 lucrene is dead no electric at all
first check you battery and terminals going to the battery, second check your main fuses. some are along side the dash when you open your door. the other big fuses you want are under the hood. theres is a black plastic box with a clip in the center usually drivers side. open the panel and notice large fuses. these fuses power the higher voltage accessories, AC, blower for heater computers, starter alternator etc. pull one at a time. hold it up to the light and look for a broken fillament if good replace and move on to the next. Also check on the bottom of your steering colum. Many times there are a clip bracket that holds all the wheel, signal, ignition controls etc. check to see if the plugs and wires coming down the steering colum are plugged in tight.
Apr 06, 2014 | 2011 Buick Lucerne
Fuse boxes
in the fuse box.
no year stated.
Oct 23, 2013 | Honda Ridgeline Cars & Trucks
Battery connected backwards, now headlights don't work.Any ideas?
check and see if you have a blown a fuse. in the fuse box under the hood. also see if there is a relay under there also. If so swap it with a nother one that is the same under there. also there is a fuse box located inside. there might be a blown fuse there also. Good luck.
Oct 27, 2012 | Hyundai Motor 2002 Elantra
POWER WINDOWS NOT WORKING, FUSE OK, NO POWER @ ANY OF THE SWITCHES.
You have two fuse boxes in your car. One in the engine bay and one under the dash on the driver's side of the car.
For the power windows, here are the fuses you should check: 15, 37, 28, 26, 24, 25. Those fuses are all in the engine bay fuse box.
#15 is a big fuse, so if you have a volt meter, you can see if there is 12V to body ground on each bolt that holds it in place.
Sep 03, 2011 | 1994 Honda Accord
How to change starter on 1994 corolla
The sizes given are the wrench sizes needed to perform the step.
1. Remove the negative battery cable from the battery.
2. Remove the hose that connects the air cleaner to the throttle body.
3. Remove the top of the air cleaner box (4 clips on the corners).
4. Take out the air filter. Disconnect the sensor on the side of the air cleaner.
5. Remove the three bolts (2 - 12mm, 1 - 10mm) that hold the bottom of the air cleaner box to the inner fender and remove the box.
6. Disconnect the two rubber hoses on the top of the air canister (one large, one small).
7. Loosen the clamp bolt (10mm) (be careful as there is a non-captive nut that will drop if you remove the bolt completely) and slide the air canister out.
8. Remove the two bolts that hold the fuel filter on to its bracket (10mm). It is the same bracket as the air canister's.
9. Remove the air canister/fuel filter bracket by removing the four bolts that hold it in place (10mm).
10. Remove the wire harness/hose bracket directly in front of the top starter bolt (12mm) - this will facilitate your ability to get a socket wrench on the starter bolt. On my car it was RIGHT in the way!
11. Loosen the top starter bolt (14mm).
12. Loosen the bottom starter bolt (14mm) and remove it completely.
13. Hold the starter up and remove the top bolt completely. Flip the starter over and place it on the drive axle below with the wiring facing up.
14. Disconnect the solenoid plug and the starter cable (12mm).
15. Remove the starter by snaking it through the driver's side of the motor compartment. There's enough room if you're patient - be careful not to snag anything and damage it.
16. Snake the new starter down through the driver's side reverse of the way the old one came out. Lie it on the drive axle and connect the solenoid connector and the cable.
17. Flip it over and up into place. Hold it in place and start the top bolt. Tighten it by hand enough that the starter stays in place by itself.
18. Start the bottom bolt; tighten it up all the way.
19. Tighten the top bolt the rest of the way.
20. Connect the battery cable and try the starter - before you put everything back!
21. Replace canister/fuel filter bracket and bolt the fuel filter in place.
22. Slide the air canister in and tighten the clamp bolt. Connect the two rubber hoses on top of it.
23. Install the bottom of the air cleaner box; plug in the sensor.
24. Put in the air filter and then replace the top of the air cleaner.
25. Connect the big hose from the air cleaner to the throttle body.
NOTE: You may have to reset the "check engine" light when you're finished (I think starting the car when we check it in Step 20 can freak out the computer since there are still things disconnected). To do this, find the fuse block on the driver's side of the engine compartment; remove the 15A EFI fuse for 30 seconds. Put the fuse back in - the light should now be reset.
That's it! Shouldn't need another one for another 150,000 miles!
A helpful rating and an testimonial would be greatly appreciated if you are satisfied with my solution ...
Oct 03, 2010 | 1994 Toyota Corolla
Fuse box on 02 low rider
Hi Strange7daze, on a Dyna all fuses, circuit breakers, relays, and modules will be behind the left side panel cover secured by grommets, four nuts or screws. On later models the electrical panel bracket cover secured by four nuts or screws must also be removed to gain access to electrical components. Good luck and have nice day.
Jun 14, 2010 | 2002 Harley Davidson FXDL Dyna Low Rider
1992 dodge caravan electrical
Check this and see if yours has the same problem!
The main cable going to the under-hood fuse box was rubbing against the metal bracket that the fuse box mounts on. Can we say poor electrical layout?? It had rubbed the sheathing off the cable and had broken one wire (the one supplying power to the instrument panel.) So I fixed that and cut a section of rubber hose and put it over the bracket to help prevent such events from occurring in the future.
Apr 06, 2009 | 1992 Dodge Caravan
Where is the body control module located on a 1997 town & country
It is located on the back side of the underdash fuse box (junction block). You remove the lower steering column cover and knee blocker reinforcement. Then remove two plugs from the bottom of the BCM.
Remove the bolts holding the junction block to dash panel mounting bracket. Remove the junction block from the bracket. Remove screws holding the BCM to the junction block. Slide the BCM downward to disengage guide studs on jb from channels on BCM mounting bracket
Mar 23, 2009 | 1999 Chrysler Town & Country
Where is the Body Control Module located?
It is located on the back side of the underdash fuse box (junction block). You remove the lower steering column cover and knee blocker reinforcement. Then remove two plugs from the bottom of the bcm.
Remove the bolts holding the junction block to dash panel mounting bracket. Remove the junction block from the bracket. Remove screws holding the bcm to the jb. Slide the bcm downward to disengage guide studs on jb from channels on bcm mounting bracket
Remove bcm from jb.
Jan 02, 2009 | 1999 Chrysler Town & Country
Hammering Logo
67 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
