Question about Jenn-Air Attrezzi JSM900 Stand Mixer
Black residue on mixing attachments
The beaters were fine and shiney for the first few weeks but then started turning black and it would get on everything..and was hard to wash off.
I have to scrub them both befor and after using them. Is there a solution for this problem? Jenair hasnt been any help and I cant get them to tell me if there is a stainless steel replacement for these crapy aluminum beaters
  • email699 Apr 04, 2009
    I have a kitchenaid mixer, not sure where it was manufactured, but not exactly a "cheap off brand" the other poster recommended returning. And yes, the whisk attachment has oxidized at the top and leaves black residue. It's disgusting.
  • 3 Answers
Aluminum tends to oxide when its washed under harsh dishwasher detergents. I use Palmolive oxy dish soap (blue bottle) just by trial and error. Put some on a sponge/ (non-metal) scouring pad, and scrub the attachment, it will take off the majority of the gunk that's rubbing off and after a few times of cleaning it, it'll get back to its aluminum luster. Easy remedy to clean your dough hook -- or any other aluminum item.
Posted on Sep 19, 2009
  • 135 Answers
Take a look and see what country the mixer was made in. If it's made in China, it may be made of a cheap alloy metal which is oxydizing, similar to steel rusting. There is probably no solution available for you if the manufacturer will not respect their warranty (if you have one). Their warranty should read: (we warranty this product for a period of # months or year to be free of defects from materials and workmanship). If you don't posess a warranty, then you should get a different mixer. Go to www.consumeraffairs.com. Look through mixer reviews and problems. It will assist you to learn from others, so you can make an educated choice for your next mixer. If you found this solution helpful, please rate it. Good luck. Ricardok45
Posted on Jan 09, 2009
Proctor silex hand mixer, brand new, just out of box, worked fine for quick on/off test, and then...NOTHING. Wont turn on?? Store is closed until tomorrow, I NEED it for what hv to cook tonight!!
Are the beaters installed? some of the newer ones require the beaters to be inserted fully. Try unplugging from the wall then remove and re-insert the beaters. Then plug it back in and try it.
If not, it might be the motor. These are very inexpensive($12 on amazon) and are known for problems. I would plan on buying another and returning this one if the beater thing doesnt work.
Oct 16, 2016 | Proctor Silex Easy Mix 5-speed Hand Mixer...
Sunbeam beaters hitting each other
Check with Sunbeam. The beaters may have to be replaced.
Dec 11, 2013 | Cuisinart Food Mixers
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
The rotating head on the mixer keeps falling off. how do you get it to stay on? it comes off when were mixing.
The Planetary plate comes attached to the shaft from the factory. It is not supposed to get
loose and come apart but it often does due to the mixer's vibrations and the user's constant
attaching and removals of the flat beater, wire whip or dough hook onto the beater shaft.
Try to remove the Planetary plate first : Gently rock it from side to side while pulling on it
to separate from the shaft. Notice the groves on both the shaft and inside the planetary
housing. That is how they are attached to one another at the factory (just friction, no screws
or pins). Now for a permanent solution:
Take a trip to Home Depot or Ace hardware and buy the J-B Industro Weld Compound
(Not the 5 minute type). Mix an equal amount from both tubes (Black and Red). Use a Q-Tip
and apply a thin layer of the mixture on both the shaft (grooved section) and inside the
planetary housing. Now re-attach the planetary plate to the shaft. Use a long strip of duct tape
to hold the plate in place (to prevent it from falling back out). Allow the epoxy to dry overnight
or at least for 8 hours.
The Planetary assembly is now permanently attached to the shaft of the mixer.
Jun 10, 2011 | KitchenAid ProLine 600 Stand Mixer
I just got my mixer a few weeks ago for Christmas. I have made cookies twice. My problem is that the bottom of the bowl doesn't get scraped. The first time, I ended up putting more flour in the dough...
Put the flat beater on and mount the bowl to the machine. Now look for the screw next to where the beater mounts on the head- this is the adjusting screw. Turn it counterclockwise to lower the beater, just a quarter of a turn, and then check where it's running in the bowl. Repeat as necessary. If you need to raise the beater, just turn the screw the other way.
lp
Jan 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My KitchenAid Professional 6 mixer has been used about 2 years. Lately it leaves a black trail in my icing/batter/whatever from the finish being worn off the metal beater--the triangular one. The bowl has...
It sounds like you have two problems. First, the black marks are usually because of a reaction between the beater and certain chemicals used in dishwashers. Try washing the beater by hand and scrubbing it throughly to remove any residue. If this works, don't use the dishwasher again. You could also buy a plastic coated beater.
It also sounds like the bowl height needs adjusting. There is a screw just under the head for this.
Jan 08, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Jun 04, 2009 | Hobart N50 Stand Mixer
Beater rubbing bottom of bowl
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Feb 14, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
Jenn-Air Attrezzi JSM900 Stand Mixer Logo
1,029 people viewed this question
Top Jenn-Air Food Mixers Experts
Oscar Netto
Oscar Netto
Dennis Boxerman
Gerry Harvey
Gerry Harvey
Are you a Jenn-Air Food Mixer Expert? Answer questions, earn points and help others
