Question about Nikon D80 Digital Camera with 18-135mm Lens
D80 -- at startup, the control panel display shows r07
When the r07 message is displayed, the camera does not operate
  • Randy Wheatley
    Randy Wheatley May 11, 2010
    repairmikes,
    What are the other circumstances when this error code come on and is it blinking? Some of these codes happen when just after something happens, say changing the lens or the SD card.
    randy320sgi
SOURCE: Memory buffer error - r07
I have the same problem with mine, unbelievable. desparate!
Posted on Jan 29, 2008
SOURCE: Nikon D80 display panel F--
bayoned not conecting proporly
Posted on Aug 09, 2008
SOURCE: Nikon D80 'error' and 'clock' message
My d80 shutter is malfunctioning. After a good shot a flashing ' error' message is display on the control panel. The image is alternately capture.My d80 is almost a year now.
Please help me
thank you,
Riche
Posted on Nov 11, 2008
randy320sgi
  • 121 Answers
SOURCE: Nikon d80 won't turn on
Pcog3 & Guests,
Check to make sure (before you turn aon the camera) that the SD card is seated and lens is completely in the right position, if it's not the camera will malfunction and stay or turn off. The last guest that doesn't have info on the LCD can turn the menu items back on in the settings preferences.
randy320sgi
Posted on Jan 07, 2009
SOURCE: "Err" appear in the viewfinder and LCD display
i have a Orite Mv 3115-Real Dv Mpeg4Vga resolution 30 FPS Digital Veidio Camera. no the problem that the battery of my camera down and i sent that with my friend to bay a new for me unfortunatly he miss that on travel so i need to fins a new battery for that
i hope sir you can healp me to find one and a charger too
Posted on Feb 15, 2009
I just bought a sigma 70-200 f2.8d ex apo hsm for use on my Nikon D3100 yet and it won't work despite the seller saying it works on his same model, it managed to work for about three pics then nothing and...
R07 is just the number of shots remaining in the camera's image buffer. It is not an error number.
The Sigma EX 70-200mm f/2,8 APO HSM DG Macro is listed a compatible with the Nikon D3100.
Did you check the AF/M switch is set to AF?
I hope this helps in some way.
Oct 08, 2014 | Cameras
Nikon d80 camera shows err error, when shutter is pressed the amount of shots remaining, shows er07. shutter works, but no picture is taken. Bracketing sign is also on display and wont go off.l
failure of the aperture unit is the usual cause - usually the contacts for the phase switch have come loose from the gear. You can find info on this by searching for the problem on the internet, including how to repair it.
Apr 06, 2013 | Nikon D80 Digital Camera
Connected a cable release the first operation of which has caused the shutter to "freeze". Error message reads r07. Display screen showing other functions such as auto focus, exposure readings,file size,...
1. Try removing the lens, fire off a few shots to confirm the mirror flips up and the shutter opens. 2. If that doesn't work, go into the menu and find "reset".
Aug 24, 2010 | Nikon D70s Digital Camera
Hey there! can you tell me what the symbol r07 iin the bottom right corner of my Nikon D80 might mean? ]cause i have this error and thecamera doesn't take pictures. can anyone tell me how to remove this...
It is the amount of remaining shots the camera buffer will hold. Page five of the manual show the LCD and page number for each item therein. Turn to page 36 for a full explanation of the buffer.
Aug 24, 2010 | Nikon D80 Digital Camera with 18-135mm...
When I put on the D80 Nikon camer with 18-55 lens showing err 10 or 11 in small display in place of frame counter. Otherwise auto focas work, even camera klik but picture not expose then what is the...
Hi nrkelkar, In the D80 manual page 36 it speaks about the buffer. What you see as an error message is r with a number. The number is how many shots the buffer at that moment can handle. It is not an error message.
Jul 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error message on my Nikon D80
I have the same message r07 on the same camera & lens combination. It is an lens error message that the lense will not focus. You can manually focus the lens in the auto mode and the camera will allow you to take a picture. I have been told it is the MR unit and cost of repair around $135.
May 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
Where's the shooting information of d80 in the larger screen?
The Shooting Information screen was introduced with the D40. The older D80 does not have it. Instead it shows almost all of the information in the control panel and/or viewfinder, though you have to delve into the menus for some of it.
Most of the settings you could change via the Shooting Info screen on the D40, you can change by pressing the appropriate button and turning one of the command dials.
The D40 was intended as an introductory dSLR, doing more handholding for new photographers, putting things into visual, menu-driven screens. The D80 was intended as a midlevel camera, allowing faster operation using more buttons. It does less handholding, but once you learn where the controls are, it actually is faster to use. (Okay, that was based on my personal experience, since I've used both.)
Error in D70s
The r07 is just a display that tells you how many pictures you have memory for in the buffer. It's not an error code at all. It will change when you change resolution, since pictures at low resolution take less memory than at high resolution. On the D70s this number will go from about r04 to r11 as you go from RAW down to low resolution.
Jan 28, 2010 | Nikon D70s Digital Camera
My d80 with 18 - 135 mm lens often does not work in the automatic mode and the screen shows 'r07'. It works in all the other modes and sometimes even the automatic mode will work. Any suggestions? VM
What focus mode? In AF-S the shutter won't release until focus is acquired.
The r07 isn't an error. It's simply telling you how many more pics you can take in burst mode before the buffer fills up.
Dec 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
62 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
