Question about LG DU-42PX12XC 42 in. Plasma HDTV
Colored Lines Half the screen is blocked by colorful lines running vertically through the screen. You cannot see the picture behind the lines, it is black.
  • Chuck Delong
    Chuck Delong Jan 08, 2009
    Where do I buy the parts and how do I replace them?
  • Anonymous Mar 28, 2014
    Serial #B0050634929352
  • 790 Answers
Hi
You have defective vertical output IC. and 1.5ohms resistor. this two parts need to replace a new one.
No other...
Thanks!
Posted on Jan 08, 2009
  • carlos fernandez Jr.
    carlos fernandez Jr. Jan 08, 2009
    go to nearest electronic parts store!
    But first open the cover of your unit.. then you can see the vertical output IC Standing attach in aluminum heatsink. then the resistor you can see the burn resistor near at vertical output IC.
    Thanks!
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Oct 04, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Vertical colored lines on top and bottom of screen
Definately a video processing problem and it may need a logic board it is called. Does the set work fine if you feed component into set to bypass all that? Let me know. GURU JAY
Sep 11, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
LG DU-42PX12XC 42 in. Plasma HDTV Logo
758 people viewed this question
Computer Repairing
Computer Repairing
