Question about JVC FS-G5 CD Shelf System
Error code "protect" comes on the scree when turned on
When turning on the fs-g5 it imediatly posts protect on the screen and turns itself off
  • idhouser Jan 11, 2009
    the reset button is not on the unit iside or out . the 24 hr unplug did nothing any more ideas? happy for any help
WHERE IS THE RESET BUTTOM FOR JVC FS-G5. THANK YOU VERY MUCH.
Posted on May 13, 2009
  • 2,071 Answers
This a memory problem ,try to look for the reset button and press it . If you can't find the reset button then the other option is unplug the unit for 24 hours the purpose is to reset and dessipate or drain the charged current .
Hope it may help you;
Regards;
VOTIT
Posted on Jan 08, 2009
HT4500 'Protection' error code appear after its turned on & turns itself
U have a serious problem and the unit is shutting down to protect itself against further damage. Check the power supply and power output stages for bad parts responsible for the condition.
Jul 31, 2015 | Audio Players & Recorders
Mitsubishi big screet HDTV after being on for a minute, the scree pops and goes black with some red lines, then the volume turns all the way up by itself.
Do the self check----if set has been unplugged plug it in and turn on for it to fail----when it shuts off ON THE FRONT OF THE SET press and hold both the menu and input (device) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like, 1 blink, 2 blinks and pause and repeat it for a total of 5 times.
What if any error code do you find?
Jun 16, 2012 | Mitsubishi WS-55513 55" Rear Projection...
My laptop won't go on properly just has a black screen & keeps rebooting
Sounds like you have the "blue screen of death" , BSOD, problem. You need to determine the error message so it can be fixed.
Restart your computer and hit F8 several times a second until you have a black and white scree with several options. One will be "turn off restart on error" Turn that off.
Now when you get the error you can see what the message is. Post it here for more help.
Oct 10, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
The laptop stays on for few minutes and then it turns itself off but before it does that, it shows a large blue scree and some large white text, the text flicks a little but fast to the point where I can...
First of all Turn of your laptop.
Now this time when you turn on your laptop start tapping F8 Key on you keyboard when you Toshiba logo. Tap F8 key for at least 5-6 times.
You will get a Windows Advance Option Menu. You will see lot of options over their written in white text. Your mouse will not work on this screen. Use UP and DOWN arrow keys on you keyboard and highlight Last known good configuration. Once highlighted press enter on it. See if you computer boots. If it boots try doing a restore.
If it doesn't boot.
Turn off your computer and then turn on your computer. On Toshiba Logo screen tap F8 key once again and go to windows advanced option menu screen once again and this time hightlight Disable automatic restart on system failure. Now when you see Blue screen coming up on your computer once again your computer won't restart. Now you can write down the information to trace out the blue screen that is occurring on your computer. Write down the Error code which will be in form of STOP 0x000000XX, you find this error code somewhere at the bottom of the blue screen.
Once you get the reply here, we will see what we can do.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
Kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Feb 02, 2011 | Kyocera FS-1016 Printer
Green light on front of tv flashes. Screen stays black
The flashing light indicates protection mode and is a generic error code.
Google for a service manual and read the error code may help.
Protection mode = the tv detects a problem and is preventing itself from turning on and damaging other components.
for more info and detail of likely causes post your tv model number.
for parts check
http://rns-systems.com/
Oct 16, 2009 | Apex Digital Televison & Video
Error code 4200-002678 call for service
best case scenario... laser scanner harness or cable loose or bad... medium case scenario... laser scanner unit is bad... worst case scenario main board is bad...
May 20, 2009 | Kyocera Mita FS-3820N Laser Printer
Vs-50607 turns off by itself it might come on after about 8hrs
if you hold menu and input on the front panel it will blink a code to tell you
where the error likely is. hold the buttons for 5 seconds and you'll get a 2
digit error, like 1 2 = no error..
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
let me know what you find.. it will determine area of failure
Jan 08, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Unit turns on, then clicks off with a "protect" message
You have a bad speaker on this unit or the audio output circuit is in need of repair. Try to disconnect all of the speakers and then turn on the unit. If it still stays in protect, you will need to have this unit serviced, unless you understand how these solid state circuits work. If the unit does come on without the speakers, turn off the unit and add one speaker at a time until the unit will not turn on. Disconnect that speaker and have it checked out or have the wiring checked out. Good Luck
Jul 14, 2007 | JVC FS-G5 CD Shelf System
Cd player opens when turned on and will not function
JVC recommends leaving the unit unplugged for 30 minutes to reseet the system - I'm trying that now, and will keep you posted!
Dec 07, 2006 | JVC FS-G5 CD Shelf System
JVC FS-G5 CD Shelf System Logo
584 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
