Question about Dell E152FPc 15" TFT LCD Flat Panel Monitor
After monitor is turned on, it goes blank after a few seconds...
After our computer is turned on, the monitor stays on for about 2 seconds, then the screen goes blank. The power is still on (indicated by the green glow of the power button), but there is NOTHING on the screen...
Well if that did not work, then open up the monitor and replace four transistors (C5707)on the inverter section of the monitors board, that should fix it.
Posted on Sep 26, 2012
    President:
  • 8,637 Answers
Sounds like the cable that connects the monitor to the computer hass a loose wire connection in it.
When it turns green, try flexing the cable near the connectors and see if the color changes on the monitor. I suspect that you have a wire in the cable that was not soldered properly by the manufacture.
If it changes color, I'd contact who you bought it from and have them replace it.
Hope thid helps. Bud
Posted on Jan 23, 2009
My Soyo monitor (DYLM1998) stays blank (black) except when it is turned on, the monitor shows a picture for 2 seconds and then goes blank again. If I turn the monitor off/on several times, it finally...
your power supply has a short in it this is comon ive seen this before try to replace cord if attatched take it to someone for repairs if not attatched its the cord most of the time loose wire..
Apr 10, 2011 | Soyo DYLM1998 Monitor
My monitor goes blank after a few seconds of turning my computer on. I turn off the monitor & turn it back on again and it only stays on for a few seconds thanks
It basically goes to Power Save Mode. Check for the same error in System Setup screen, if the Monitor goes off in System Setup then you better need a replacement. Else you would need to reseat the Video Card(If any) and the Memory Modules. Please keep posting for any further issues / improvements.
Dec 30, 2009 | Dell Computers & Internet
I have a Soyo Monitor, Model MT-NI-DYLM1998. It had been working OK, but I put my computer in storage for 2 weeks and then tried to reconnect. The Soyo monitor stays blank (black) except when it is turned...
i have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
Dec 19, 2009 | Soyo DYLM1998 Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor goes blank after first few seconds of turning it on...
There's an internal electronic part/s of your monitor that are cold soldered / defective. I suggest to bring the unit to an authorized service to properly diagnosed & fix the problem. best regards
May 25, 2009 | Proview PT 15.1" LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Screen STAYS BLANK
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
Dell E152FPc 15" TFT LCD Flat Panel Monitor Logo
210 people viewed this question
Alun Cox
