Question about E-Machines eMachines Desktop PC
Contrast i am having problems with a box that says contrast. it pops up in the middle of the screen, can't seen to get it too go away. can you help me with this problem?
  • Whodatbe May 11, 2010
    Sounds like the monitor menu is open, the only screen your actual computer would show is the refresh message when the monitor will not support a particular refresh rate. Have you tried cycling through the monitor menu too see if it will close or exit?
  • Thomas F. Schneider May 11, 2010
    What monitor do you have. The message is likely from the monitor.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
On the side there should be a set of buttons. one of them will close the screen
Posted on Jan 08, 2009
Brightness/contrast menu pops up in middle of my screen and won't go away....
press the menu button and keep pressed for 20 second untill menu does not show unlocked menu massage your problem will be solved
Apr 14, 2011 | Acer AC 713 17" CRT Monitor
The brightness/contrast menu pops up in middle of my screen and won't go away.
The auto tuning buttons have been set on the televison device. Use tte remote control buttons to disable brightenss and contrast. Usually the brand of the TV makes pressing a button to allow feature fucntions to be acheievable. Press the same button after settings are acquried to disble the function else would continue to exist assuming user request still applies.
Feb 06, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
Contrast window pops up and dims the screen.
You are not alone. I have a Viewsonic monitor that does exactly the same thing. Wasn't sure if it was the monitor or a "bug".
Dec 10, 2009 | ViewSonic VX910 19" LCD Monitor
Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Sep 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Jul 28, 2009 | ViewSonic E70f 17" CRT Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Contrast pop up
Is the OSD button stuck on the front of the monitor? Can you control the OSD menu with software or firmware? It may be the button interface/hardware.
Jan 03, 2009 | Computers & Internet
Dell E173FP 17-inch Flat Panel Color LCD Monitor
The dell monitors are bad with capacitors going out, check caps in power supply and video board. You can use a can of freeze, it would be easier that way. Just be careful not to touch anything, because these monitors can shock easy.
Sep 06, 2006 | Dell E173FP 17" Flat Panel LCD Monitor
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
